KUKA KR125/2 Tj KRC1
  • najafabadi
  • November 20, 2009 at 1:48 PM
  • najafabadi
    56
    Hi everybody,
    What is the difference between normal KR125/2 and a KR125/2 Tj one?
    Can somebody send me some information about Tj models. I couldn't find any useful information.
    Many thanks in advance for your help.
    Najafabadi
  • SkyeFire
    1,062
    9,465
    • November 22, 2009 at 1:18 AM
    This is digging waaaay back into a very old memory, and I could be entirely wrong, but I think that TJ and ZH are two slightly different arm versions -- the ZH superceded the TJ because the ZH was more durable, IIRC. The kinematics are different enough to require different system settings.
    The way to tell a TJ from a ZH, again IIRC, is that the bolts holding the Axis-3 joint together are divided into three clusters, rather than making a simple continuous ring.
  • optimus_prime
    30
    • November 26, 2009 at 11:28 AM
    Basically 2 companies from where robot Gearboxes are coming.
  • mechrob
    • December 11, 2009 at 11:13 AM
    There are many different types:
    KR125/1, with ZF94 gear units for main axis + ZHII (=wrist)
    KR125/1a, with ZF98 for A1 + A2 and ZF94 for A3 + ZHII
    KR125/2 = KR125/2 TJ, with Tejin gear units for main axis + ZHII
    KR125/2 ZF, with ZF98 gear units for main axis + ZHII
    KR125/3, with ZHIV, the arm has an open side so you can see the flexible cable-tubes.
    KR125/4, with ZHIII, also the arm has an open side so you can see the flexible cable-tubes.
    The Tejin and ZF94 gear units have the same type of gear-oil, but the ZF98 needs a different type of oil.
  • basbasan
    65
    • January 30, 2015 at 10:16 AM
    ı have a krc2 kr125L90/3 ZHIV. which mada file ı need to load to system. as ı see there two type of mada files for 125/3 model. and both are for tj model. ı tryed both but robot's orientations arent looking good. is there any thing ı m missing?
Users Viewing This Thread
  • 1 Guest
