Align Tool working Direction To Base
  • SU05LLY
  • August 30, 2019 at 11:34 AM
  • SU05LLY
    30
    Hi All,
    My first post , but admittedly a novice feeling on this one , so hoping your able to defragment my mind ,
    Process is a vertical linear stroke mounted onto BASE_DATA[1].
    I'm want to align the TCP of the hole to the BASE so that the bore of the hole is in alignment essentially. I'm sent the values of a hole ( X/Y/Z/A/B/C ) relative to the flange ( via CAD / CATIA )
    The Robot is Ceiling mounted.
    The working direction of the tool is "X".
    The TOOL_DATA / BASE_DATA are as follows:
    TOOL_DATA[3] = {X 36.0810,Y -0.00200000,Z 124.750,A -4.02600,B 89.4660,C -5.50200}
    BASE_DATA[1] = {X -211.718506,Y -246.207,Z -1222.30701,A -0.502900,B 0.140900,C -0.129100}
    The .SRC is written is KRL , so any help is massively welcomed.
    Additional info , the KSS is V8.3.39
    robot Type is : KR6-700-2
    Rough .SRC as follows:
    DEF basepositioningdemo(FI_nToolNr : IN)
    ;* Description: BasePositioningDemo *
    ((((Note I have delected folds for initialisations etc.....))))
    $TOOL = TOOL_DATA[FI_nToolNr] ; CAD/CATIA Imported X/Y/Z/A/B/C
    $ACT_TOOL = FI_nToolN
    $BASE = BASE_DATA[1]
    $ACT_BASE = 1
    IF CALCULATIONS () THEN
    MsgQuit("Confirm Your Ready") ;Capture Slow Reaction *TEMP*
    PTP XSample1 ; Adjust Via OverView Screen For Testing
    ELSE
    MsgQuit ("Confirm Your Mistake!!!!") ;Capture Slow Reaction *TEMP*
    ENDIF
    ; Drive to Xhome
    END
    DEFFCT BOOL CALCULATIONS ()
    ;FOLD HEADER
    ;ENDFOLD (Header)
    ;FOLD DECLARATIONS
    DECL BOOL _bResult , _bDataValid[6]
    ;ENDFOLD (Declarations)
    ;FOLD EXECUTABLE
    $VEL.CP = 0.01
    ; _bResult = _bDataValid
    _bResult = TRUE ; No Data Checking During
    RETURN _bResult
    ;ENDFOLD (Executable)
    ENDFCT
    Many thanks inadvance Forum.....
    Edited once, last by SU05LLY (August 30, 2019 at 12:10 PM).
    Leon
    32
    5
    463
    • August 30, 2019 at 2:52 PM
    I am sorry, but i am not seeing a Question here. What is giving you problems? Am i missing something?
    SkyeFire
    1,042
    9,388
    • August 30, 2019 at 3:41 PM
    Quote from Leon
    I have to agree, what's the question?
    Are you trying to align the TCP with the Base? That's straightforward -- simply active that Tool and Base, and program a position with ABC values that are multiples of 90 (which ones depend on which axes you want to align -- 0,0,0 would align all 3 axes, while 0,0,180 would would make the X axes parallel, the Y& Z axes antiparallel. And so on)
  • SU05LLY
    30
    • September 6, 2019 at 6:13 PM
    Appologies for not getting back , task switching hasn't helped.
    So the main issue , is that by switching the robot from an FLR to a CLG via orienting C 180 , this has had an effect on the moves , meaning we have had to add to the motion "XExample.C" to 180.0 in order to run , by my own naivety , I assumed the flipping of the robot to CLG mount would of sorted this out .
    Sully
    SkyeFire
    1,042
    9,388
    • September 6, 2019 at 6:57 PM
    "Switching the robot from FLR to CLG"? What? What did you change? What C value?
    If the robot is really changed from FLR to CLG, that will normally rotate $WORLD so that Z+ is still anti-parallel to gravity (i.e., "straight up"). If all you did was change the Base by rotating it C+180, then no, that won't work -- you have to fix the Bases in all 6DOF. The simplest way to do that is re-teach the Base(s) after the robot has been physically moved. This is a regular thing, although switching between floor and ceiling mount is a rather extreme case.
    panic mode
    1,267
    13,037
    • September 6, 2019 at 7:14 PM
    i think he just meant to change $ROBROOT but ended modifying programmed points or frames
    but modifying $ROBROOT is only software change. for many robots hardware need to be changed too (different counterbalance and possibly change oil quantities in main axes) but this is small robot and only needs $ROBROOT mod.
    SkyeFire
    1,042
    9,388
    • September 9, 2019 at 3:40 PM
    Yeah, I actually wrote a section about that, then looked at his robot model again -- it's a Sixx, and I'm reasonably sure those don't have counterbalances.
    However, I am somewhat concerned about the robot's gravity compensation -- I've never had to set up an Agilus in a non-standard mounting, but I have to assume that it needs accurate information about the relationship between gravity and $ROBROOT in order to properly account for payload effects. At low payloads and speeds, a ceiling-mounted robot that still thinks it's a floor-mounted robot might not throw torque errors, but as speeds and/or payloads approach maximum, I'm reasonably confident that the OP will start seeing issue.
    panic mode
    1,267
    13,037
    • September 9, 2019 at 7:08 PM
    I did plenty of times. Ceiling or wall mounted Agilus is no problem
Similar Threads
  • Robot way off
    • 4wheeled
    • September 12, 2017 at 1:18 AM
    • KUKA Robot Forum
  • ABC Rotation and S and T values versus IJK
    • phillfalco
    • April 14, 2017 at 7:44 AM
    • KUKA Robot Forum
  • World coordinate system table alignment
    • phillfalco
    • January 21, 2017 at 1:55 AM
    • KUKA Robot Forum
  • KUKA KR420 absolute accuracy
    • stefanristevski
    • November 3, 2016 at 11:33 AM
    • KUKA Robot Forum
