Dear My friends
i have fanuc 200 ic with controller R30ia mate
i need to edit " auto "program in Teach pendant but i have this error MEMO-093
How can i do ?
Many thanks and best regards.
Dear My friends
How can i do ?
Press Function>Abort. Also check to see if this is running in BG logic, menu>setup>BG Logic. If it is running in BG logic then stop it, make your edit and press run again. You also will need to see if it is an Auto-execute program which is selected in menu>system>config. If so then you may have to deselect it, reboot, edit, reselect it, then reboot again.
Many thanks my friend
It is OK
