I am trying to find a way to navigate programs a little easier and wanted to know if there is a way to cross reference a LBL, Var, PR or anything else to find every place it is written or read throughout the program. I know this is a feature in TIA Portal, and was hoping there was something similar for OLPCPRO. If there is even a link to a guide/manual that would be equally as helpful also.
Cross Referencing Using OLPCPro
- dixon20
- Thread is Unresolved
You can go to the robot's web server and use the search tool. It is just a basic text search that looks through every program.
In looking how to find the search tool on the webserver, I actually stumbled upon a "Find and Replace" tool through the teach pendant. In OLPCPro, under the Teach tab, it has a find and replace window that shows you which program it is in and what line of code it resides. You can even limit which program you are searching.
Awesome, I will have to check that out.
Quote
dixon20, I looked in Roboguide and found this tool. It works nicely and will be a huge time saver. Good find!
Great find. I wish I'd known about this tool sooner.
It appears to work very similar to the Search tool available on the robot web server, except that web server tool can only Find, not replace.
Hawk, when did the search tool get added to the web server? I have a RJ3iB (Software version 6.31) and I don't see any search tool on my web server.
It has been available at least since R-30ib (v 8). I'll have to check if v 7 software has it and get back to you.
