Hi i would to ask why after i did modify position, the position still remain at old point which is like i never modify the position.. and how to fix it? thank you..
Robot positioning
FarisHanafiah -
August 24, 2019 at 4:50 AM -
Hi
Is it a * point or a robot target ?
There may also be an instruction somewhere that is overwriting the position you are modifying:
pRobTargetA:=pRobTargetB;
Also seen modules loaded at startup from the Home directory that overwrite any changes that may have been made. You have to save the changed module to replace the called module.
If the position is part of an array, you may be modifying a point elsewhere in the array. A position that has an { } at the end is usually in an array. Example:
x:=nJobNumber;
MoveJ pRobTargetC{x}, v300, z50, tool1;
