Advertising
TPIF-140 Connection Limit Exceeded
  • Hello,
    When I try to connect to my iPendant via IP Address, it opens a new window with TPIF-140 error showing instead of the iPendant. I have opened it via IP before, many times without any issues. How can I clear this? Note: None of the previous instances of the iPendant are open anymore and I dont know of a way of accessing them.
    Side question, is there a way to choose which BCKED I use. I know BCKED4 is the first window of the online pendant and 5 is the second window, but is there a way I can force using BCKED6 or 7 or 8?
    Thanks a lot!
  • Code
    1. TPIF-140 Connection limit exceeded
    2. Cause: An attempt to log into the teach pendant menuing system from an external web browser has failed because the
    3. connection limit has been reached.
    4. Remedy: The system variable $UI_CONFIG.$NUM_CONNECT controls the number of external connections allowed. The
    5. maximum number of connections is five INCLUDING the teach pendant. Reconnect the external connections in your
    6. system so that no more than five exist.
    "I could tell that my parents hated me. My bath toys were a toaster and a radio."
