  4. ABB Robot Forum
Connect with 2+ ABB Robots with IRC5 Compact controller
  • Nox
  • August 21, 2019 at 10:47 AM
  • Nox
    30
    Hi everyone,
    I'm struggling with connect through ethernet cable (service port) to 2 ABB Robots using ICR5 Compact controller for each.
    Both controllers have the same IP (192.168.125.1) and I'm not able to change the IP of the robots to connect simultaneously using a network switch.
    I've been reading something regarding an X-Start and changing the IP, but I can't modify the IP of the service port...
    How to do this the proper way?
    Thanks in advance!
  • Knud Erik
    5
    • August 21, 2019 at 11:55 AM
    You need the option PC interface to do that. And use X6 or X5
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • August 21, 2019 at 5:27 PM
    Quote from Knud Erik
    This is correct if you are wanting a permanent connection using robotstudio and setting up jobs or editing programs and such. If, however, you are wanting only a temporary connection for commissioning or programming, you can only connect to one at a time via the service port.
  • Nox
    30
    • September 18, 2019 at 2:01 PM
    Ok, so, so far I have this:
    IRC5 Compact controller with PC-Interface (616-1)
    PC connected through X6
    I X-started the robot and place an IP 192.168.0.254, submask 255.255.255.0, default gateway 0.0.0.0
    I try to connect through the ip and the port: 192.168.0.254:2000 with no luck...
    Not even ping works for this... is there anything else that I have to do?
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • September 18, 2019 at 2:08 PM
    Did you make sure that your PC IP and subnet are compatible? I think that just the service port is DHCP.
  • Nox
    30
    • September 18, 2019 at 2:13 PM
    I put my computer ethernet connection in the IP 192.168.0.253, and now the ping to the robot's ip works, but still not able to connect...
  • Lemster68
    301
    2,485
    Blog Articles
    7
    • September 18, 2019 at 2:20 PM
    Connect how? With robotstudio? If so, do you have a license for RS?
  • Nox
    30
    • September 18, 2019 at 2:23 PM
    Sorry, I'm working with RoboDK and it works nice if I connect through service port with the default IP 192.168.125.1 and port 2000...
  • pdl
    270
    1,548
    • September 18, 2019 at 2:49 PM
    Quote from Nox
    Is that the default robot IP, or the default RoboDK IP?
  • SomeTekk
    17
    202
    • September 18, 2019 at 10:56 PM
    Try an X-Start and set the default gateway to 192.168.0.254. Set the control's IP to 192.168.0.XXX - NOT 254. Set a static IP - use advanced settings if needed - for the PC to 192.168.0.YYY, same subnet mask & default gateway.
    ABB Control
    IP
    192.168.0.123
    Subnet Mask
    255.255.255.0
    Default Gateway
    192.168.0.254
    PC
    IP
    192.168.0.234
    Subnet Mask
    255.255.255.0
    Default Gateway
    192.168.0.254
  • Nox
    30
    • September 19, 2019 at 8:59 AM
    • #11
    Thanks guys! I fixed it, the thing with RoboDK is that in the .mod file (RoboDK driver file) there's also an IP that it must be the same as the robot's IP. I was thinking about this since I was able to make ping to the IPs and it worked).
    So now I'm able to connect through the X6 port.
    Thanks again!
  • Nox
    30
    • September 19, 2019 at 9:00 AM
    • #12
    Quote from pdl
    That's the default robot IP for the service port (X2)
