Hello People.
I have a KCP2 and that is working strangely. I know he is passive but he takes too long to load the KSS. But only with this KCP. If I use other KCPs with the same robot, they load the KSS normal.
What can it be?
Thanks for any help.
Hello People.
What can it be?
Can someone help me?
Read the READ FIRST pinned topic. Before anyone can help you, we need much more detail.
Detalhes
Leia o primeiro tópico fixo da LEITURA. Antes que alguém possa ajudá-lo, precisamos de muito mais detalhes.
I've tried 2 robots, KR 125 and another KR 30, they are KRC2 EUROPE, the problem happens in both robots, but only with KCP2 informed above. If I use other KCP's the software loads normally.
KSS is 5.6.10.
KRC2 EUROPE.
I've never seen anything like that.
The only 'active' component I can think of inside a KCP2 would be the safety node, and that only on later-version KCP2s. I suggest comparing the model numbers between the two KCP2s. If they are of different generations, it's possible that one simply has an older safety node that takes longer to start up and connect to the ESC board.
Sure, Thanks for Feedback. I'll see what I can do.
this is very odd... but KSP is not completely passive. if there is a bad cable it may cause communication loss and a lot of retries....
Display MoreHello People.
What can it be?
When KSS load with this particular KCP2, you get any error message tha contain "CAN BUS error" or something like that?
The two robots I tested have KPC running Windows 95. Today I got a KPC KRC2 running Windows XP. When testing the problem KCP, on Windows XP KPC it loaded normally! Very strange!
No Massula, no error message appears! It just doesn't load, most of the time it stays on the tech packages loading screen.
Problem solved! - The problem was the KCP membrane, I disconnected it from KCP and the software loaded normally!
Membrane? You mean the keyboard/keypad?
Hm... I suppose that could make sense. If the keyboard was constantly sending "junk" data to the KRC during boot, that might slow down the process.
I have to say, I've never seen anything like that before.
Yes that's right, But the problem has been solved, thanks!
