Can't trigger Macro when main program is running.
  • Hi everyone,
    During my internship I was given a task to write a program which would automatically change robots path after entering DCS. I created Cartesian Position Check (CPC), connected that CPC to Safe Peripheral Output(SPO) and mapped those signals to DI/DO' so I would be able to trigger custom Macro. The problem is that when Macro is triggered (robot arm enters DCS zone) i get the PROG-040 Error and macro doesn't initiate any commands.
    My question is how can i overcome that problem and force my robot to pause main program when my it enters DCS zone and run macro subprogram ?
    Thank you in advance for your help and suggestion
  • The PROG-040 alarm is because you have a macro with motion enabled for group 1. you cannot trigger a macro while running with motion in it.
    I would try a skip label on your standard motions, and call a program/or jump to another section to change the robots path.
