How can I calculate the xyz components of a user frame given the user frame rotation offsets such that the resultant use frame position is zero. Basically trying to create a new origin point. See the attached image. I got the user frame xyz offsets by trial and error, but I want to be able to calculate them. I got the wpr offsets by measuring the mounted angle of the robot.
Calculating user frames
nerd484 -
August 10, 2019 at 2:58 PM -
Have you tried using the 3 point method to teach your user frame instead of direct entry? Then it will calculate the values for you.
Send me you backup, to see if you have the origin point. rauljimenezr89@gmail.com
Yes he is right try the 3 points method first.
It's hard to know what you're actually asking.
If you're looking to create that new user frame, everyone is right and you should use the three point method.
https://mh142.com/wiki/User_Frame_Lab
Direct entry is mostly used for when you already know how much an existing user frame is changing and just want to enter one or two measured values on the fly. This for example would be if you need to move the pickup position for products on an assembly line slightly up the line to make room for sensors or other things.
I would do the three point method however, i cant actually reach the point that will become the new zero position. The intended zero position is outside the reach of the robot. So i could use the three point method to get the frame in the correction orientation, but the xyz position would still need to be adjusted.
Search for the following post:
Rotating a User Frame by its own Z axis
You can use the matrix methods shown there to translate your frame.
If you are trying to create a new frame with a point defined in your current frame, you would just do a matrix multiply of your user frame by your point in the frame. This would give you a location in world, which you would use to define your new frame.
Wasn't aware of the Matrix functions, was exactly what i was looking for. Allows me to enter an offset along a principal axis and shift frames origin.
I dont undertad why you say that, usually Z is normal to the surface in the user frame (unless you want Z in the X or Y directions) and X and Y points are positive and you choose the orientation.
