why does it not change position? Palletpattern KRL 8.3
  • What your calculations modify and what program uses as a base are two different things....
    More precisely programmed motions do not care about value in $BASE since they all use own base value which remains unmodified
  • Thanks for replay.
    So far I understand.
    it's just that I did not succeed, to get the robot to go after my calculated positions
    I would love to get som help on my way with it.
    i have banged my head at this for a week :waffen100:
    Edited once, last by Doe ().
  • I have tested changing this line.
    $ BASE = fShiftedBase
    to:
    $ BASE_DATA [2] = fShiftedBase (this one i get error)
    BASE_DATA [2] = BASE_DATA [2]: fShiftedBase
    which code is correct?
    I've been sitting with this for a long time now it feels like, things don't look so clear :smiling_face:
  • neither.... i explained why your code did not produce any changes but .... that is not the only issue.
    you are doing this in a loop and each iteration would alter base.
    so even after single iteration base would be changed. worse, changes are cumulative.
    golden rule is to not destroy data that you will want to use later on.
  • [size=1em]you could for example:[/size]
    [size=1em]1. measure that base as base ten for example (BASE_DATA[10] is unmodified base). [/size]
    [size=1em]2. leave your motions use base 2 (BASE_DATA[2])[/size]
    [size=1em]3. and in your program before ILF motions add something like[/size]
    [size=1em] BASE_DATA[2] = BASE_DATA[10]:fShiftedBase[/size]
    4. make sure that teaching of points in your ILF is done when fShiftedBase is a nullframe
    Edited once, last by panic mode ().
  • I've learned a BASE_DATA [32] as my original base
    BASE_DATA [1] has no values. X, Y, Z, A, B, C = 0
    The positions I learned are learned in BASE_DATA [1] when everything is set to Nullframe.
    And when I test drive I get Workspace error.
    I replace BASE_DATA [32] TO BASE_DATA [1]
    It does not work completely but almost, it moves in the wrong direction;) and as you wrote it adds movement 100, 200, 300mm
    But I'm not worried about that.
    First run, i can se that BASE_DATA[32] and fShiftedBase moves in, BASE_DATA[1] but i get Workspace error.
    I have a lot to learn I know! but must get it right! :smiling_face:
    i attached the new program
  • i give up! i´am stuck! i will never get it to work. :waffen100: :motz:
    I just made sure that fShiftedBase and fShiftFrame are at 0.
    nXCounter, nYCounter is at 0
    Base 32 is learned and made a copy of it to Base 1.
    Made a Tuch up on my positions in Base 1.
    And still get workspace error.
    When I look at Base 1, the first round will be just like BASE 32.
    but in the second loop it adds the whole of Base 32 again to Base 1, which gives me very high numbers of X, Y, Z :frowning_face:
    Like I said, I'm noob at this but willing to learn :smiling_face:
  • Okay, the problem is here:
    ;create shifted Base from Original Base and Shift Frame
    fShiftedBase = BASE_DATA[32] : fShiftFrame
    BASE_Data[1] = BASE_DATA[1] : fShiftedBase ; activate shifted Base
    It should be a single line: BASE_DATA[1] = BASE_DATA[32] : fShiftFrame
    Because you shift B32, and then apply that as a shift to B1, you're getting the huge offsets.
  • Thanks for all the help!
    I got it to work with this code. now i have to get the status and turn right :smiling_face:
    fShiftedBase = $NULLFRAME ; init to all 0s
    fShiftFrame = $NULLFRAME ; init to all 0s
    FOR nXCounter = nXMin to nXMax
          FOR nYCounter = nYMin TO nYMax
    fShiftFrame.X = nXCounter * rXSize
    fShiftFrame.Y = nYCounter * rYSize
    BASE_Data[1] = BASE_DATA[32] : fShiftFrame
    POS
    ENDFOR
    ENDFOR
  • Status and Turn should not be an issue, unless your pallet pattern forces the robot to cross through a singularity (for example, A5 + in one area, A5 - in another).
    The simplest way to deal with this is probably to use a careful combination of LIN and PTP motions. While PTP motions strictly obey S&T values, LIN motions will ignore S&T settings in favor of maintaining a linear path. So if moving to particular sections of the pallet are causing the wrist to flip over, using a LIN instead of a PTP might resolve it. However, if the LIN motion suffers singularity issues, you might need to establish more than one PTP point as a good starting location for the LIN motions, and use IF statements based on the counters to control which PTP point you use. Also, LIN motions can "wind up" the wrist, which will then be "unwound" by the first PTP motion afterward. So be aware.
    Another means might be to "strip" the S&T values from your points, but that would mean you'd give up the easily teachable points. Something like
    DECL FRAME TempPos ; temporary position variable with XYZABC, no S&T or E1-E6
    TempPos = xPickPosition ; where "PickPosition" was a point taught using an Inline Form
    PTP TempPos : {X 0,Y 0,Z 100,A 0,B 0, C 0} ; move to 100mm above pick position
    LIN TempPos ; move to pick position
    ; grab object
    LIN TempPos : {X 0,Y 0,Z 100,A 0,B 0,C 0} ; move to 100mm above pick position
    PTP xAbovePallet ; Inline Form taught position, will use fill S&T so watch for the wrist "unwinding"
