Communication between Controllers
  • Hopefully quick question here. I'm working on my first multiple robot application and i want to build in some cross controller communication via Ethernet to keep their movements in sync with each other. I haven't found a good way to do that. Anyone have a good solution for this? It doesn't need to be very robust, I was planning on just sending move completions back and forth. Both controllers are also linked to a PLC that is controlling them both. I could use the PLC to snyc them, but I would rather have it bypass the plc as a secondary system.
    Update: I found the IO Cell Linker tool and have successfully 'linked' the digital out and the digital input. However when the program runs, the input status is a "?" as if it isn't reading the value. I tried doing a dioGet and just using the digital output ex: wait(do_link==true) but the "?" never goes away.... I tried a full power down to see if the IO needed to update but haven't been able to figure out this issue.
    Thanks in advance!
  • Hello snyffeler,
    the IO Cell Linker is a tool which can be used to link two or more emulated controllers to test their communication. This does not apply to real controllers. It basically is a simulation of the real wiring.
    If you want to communicate between two real controllers, you need a fieldbus or socket communication. The easiest would be a TCP-IP socket communication. One controller would be server and the other client.
    The difference between theory and practice is greater in practice than in theory.
  • Thanks Psyril,
    Yeah what I've discovered is to setup another fieldbus would require more hardware since I'm already using EIP to communicate with a PLC but that works as a master/slave (adapter/scanner).
    Do you know if it is possible to setup TCP-IP communication purely software?
  • What do you mean? You need at least a connection (RJ45 cable on J204 or J205) between the two controllers. It's also ok if they are simply in the same network. The rest is purely software.
