Fanuc R30iA - Single Axis Mastering
  • alive15
  • July 17, 2019 at 11:40 PM
  • alive15
    15
    161
    Good afternoon all,
    We will be changing out a servo motor for axis 1 soon. I have the current position of the robot written down (all the degrees for all 6 joints), but I will only master joint 1 (which is at 7° right now). After we install the servo, is it possible for me to master the robot at 7° and make it believe the servo is at that position? This way, I don't have to touch up any points at all in my program? Cause if I change it to think it's at 0°, then my program will be completely off.
    Thanks,
  • HawkME
    568
    3,268
    • July 18, 2019 at 12:54 AM
    Yes. If I remember correctly you should be able to enter what degree you are mastering at.
    In any case, if it only allows 0, then just master at 7, jog to -7, and master again.
  • R47
    110
    • July 18, 2019 at 7:05 AM
    Yes,
    I think it's under.
    Menue-Next-System-Master/cal-Single Axis Master..there you should be able to Master the Servo in every position
  • pdl
    270
    1,533
    • July 18, 2019 at 2:03 PM
    Yes you can do this, but you will have to jog the axis by one full motor revolution to establish a pulse first. It's best to setup a dial indicator before hand to get exactly back to seven degrees.
  • alive15
    15
    161
    • July 18, 2019 at 6:11 PM
    @Everyone Thank you for all the advice. Unfortunately, we had to test the gears inside the robot where all the grease is. We were able to move axis 1 gears with our hand (which I thought was wild, moving the entire axis 1 robot with just your hand on the gear), so my degrees were off. We ended up using the timing marks to get very close to zero and let the techs touch up the few loose ends.
    For anyone else in the future, you need to enable the mastering option through the master enable variable, then once you unplug the servo and connect new one, you will get BZAL error, you need to reset this by going to the $MCR.$SPC_RESET variable and setting the value to true. Then the value should go false. Then you need to master the robot, then calibrate. Then good to go!
  • Iqra Arshad
    • December 4, 2019 at 7:19 PM
    Quote from alive15
    Good afternoon all,
    Thanks,
    Hi there!
    its nice to answer your question here. you can master your Servo at any angle you want, I would like to refer you a tutorial for quick mastering single axis: Tutorial - Single axis quick mastering procedure.pdf
