  4. ABB Robot Forum
Irb 6400 wait startup in progress
  • 851dave
  • July 12, 2019 at 4:49 PM
  • 851dave
    45
    Just powered up an s4c m99 controller and it doesn't attempt to boot .red leds on all computer and memory cards, has anyone had experience of this?
  • RoboTux
    15
    • July 12, 2019 at 9:57 PM
    What is the robot history?
    Connect to console port in robot computer with serial cable and check the messages at power on.
    What is in TPU display?
    If the robot dosen't have system, or the program unimportant or you have a backup, disconnect the batteries, wait 1-2minute, reconnect, and switch on. If it isn't ok, pull off/on the two computer and memory cards, and switch on.
    ABB Robot -Programming - Service - Maintenance - Training
  • 851dave
    45
    • July 21, 2019 at 5:45 PM
    thanks robotux
    turned out to be a bad memory board !
  • Riccardo Castiglia
    30
    • September 13, 2020 at 10:56 AM
    do someone know if you can boot up a robot without the robot and ioc attached?
  • Lemster68
    301
    2,490
    Blog Articles
    7
    • September 14, 2020 at 2:00 PM
    You mean boot the controller without robot and what? is that ioc or loc?
  • Skooter
    172
    2,064
    • September 14, 2020 at 2:13 PM
    Never tried it without a DSQC532(x) I/O computer. I have had a bad I/O computer keep it from booting a few times.
    If you power up without the robot serial measurement unit communicating (unplugged or otherwise), it does take a much longer time to boot.
    Powering up without the motor cable attached give an motor PTC over-temp within the first few minutes.
    30
    • September 19, 2020 at 8:22 AM
    it still doesn't, and the light for the power supply isn't led while the io boards and the one on the right are all on fault
  • Skooter
    172
    2,064
    • September 19, 2020 at 12:49 PM
    This thread was originally for an M99 S4C IRB6400R. Is this the same? See attached.
    If it is the same, are you saying the 'AC Ok' LED on the power supply is not lit?
    Images
      • 52.72 kB
      • 439 × 627
      • 6
    30
    • September 20, 2020 at 9:06 AM
    exactly not lid, im using a generator and should be ok right?
  • Skooter
    172
    2,064
    • September 22, 2020 at 9:19 AM
    Is the generator 3-phase output correct?
    Is the controller transformer input taps configured for the input voltage.
    To get the 'AC OK' LED to come on, the power supply needs 55VAC 3-ph at connector X1 on the top right corner.
    30
    • September 25, 2020 at 10:25 AM
    • #11
    i tried cheking it and povering it with the grid current but it doesn't work what should i do?
  • Skooter
    172
    2,064
    • September 25, 2020 at 8:53 PM
    • #12
    Do you measure approx. 55VAC 3-ph at connector X1 on the top right corner of the power supply?
    30
    • September 26, 2020 at 9:14 AM
    • #13
    it is one phase 230v and it gives it
  • Skooter
    172
    2,064
    • September 28, 2020 at 3:52 PM
    • #14
    My assumption was this was an M99 as stated in the title. Can I assume you have an S4C+?
    What is the status of the LED on the power supply - Off, Red, or Green?
    30
    • September 29, 2020 at 10:42 AM
    • #15
    it is a red led turned off
  • Skooter
    172
    2,064
    • September 29, 2020 at 2:38 PM
    • #16
    Seems like a bad power supply.
    LED Status for DSQC506 Power Supply:
