How do i setup the thickness check if one of my plate is 3.5 and the other one is 2.7 ? When i close the gun manually to both part the measurement of the gun is 4.5. on their setup their under thickness limit is 0.5 and over thickness limit is 0.3. how do they get this number?
Thank you
Thickness Check
- iteody
Could you tell more about your application? Why you are measuring this plates, what gun you are using, robot, etc
Could you tell more about your application? Its a spot welding application
Why you are measuring this plates,? The sensor was loose and detected with out the other plate and welded. thats why i want to enable the thickness check.
What gun you are using,its an x2c style obarra gun
THe robot is Fanuc R2000 R30 210F
The controller is R2000ic
Thank you -
Hi ideoty,
here is a good description about that Funktion.
I hope it helps you. -
Hi R4, Is there a system variable for Thickness Check Enabled/Disable ? The manual you posted does not indicate anything
how to set thk chk logic if my one sheet is of 2.0mm and if other sheet overlap with this sheet then sheet thk becomes 3.2 mm, and how to get alarm?
