Fanuc- Pos2Joint
  • Hello,
    I would like to get a Cartesian PR with UF, UT and then convert it to JPos with Pos2Joint.
    Do you have an example Karel?
    thank you. :help:
    it's my karel code no default or result
    BEGIN
    Pos_Actuel= CURJPOS(0,0)
    -- Recuperartion des entier de la routine TPE paramétrée
    GET_TPE_PRM(1,data_typ,data_init,data_real,data_str,STATUS)
    ValPrDebut=data_init
    --Recupe PR en cartesien
    Pos_Debut=GET_POS_REG (ValPrDebut,STATUS)
    Pos_UFrame=GET_POS_REG (60,STATUS)
    Pos_UTool=GET_POS_REG (61,STATUS)
    --Convertion pos cartesien en Joint
    POS2JOINT (Pos_Actuel, Pos_Debut, Pos_UFrame, Pos_UTool, 0, wjnt_cfg, Tab_PR_Debut, out_jnt,status)
    END CheckPos
    Edited once, last by krugorr ().
  • I got it working for me at some point.
    The reason I needed it was to check to see if a linear move was going to have a config or singularity issue.
    my code:
    This should be called from a TP program as:
    : CALL K_POS2JNT( 1, 2, 3, 4) ;
    Where PR[1] will have the joint result
    PR[2] is the position register with the caretsian point to convert
    3 is the number of the UFRAME
    4 is the number of the UTOOL
    PROGRAM K_POS2JNT
    -- translator directive
    %COMMENT = 'Cartesian to Joint Coord Conversion'
    -- program vars
    VAR
    result : INTEGER
    status : INTEGER
    data_type : INTEGER
    int_value : INTEGER
    real_value : REAL
    str_value : STRING[10]
    dummyConfig : CONFIG
    dummyArray : ARRAY[1] OF REAL
    currentJPOS : JOINTPOS
    cartPos : POSITION
    UF_Ref : POSITION
    UT_Ref :POSITION
    jointResult : JOINTPOS
    resultPR : INTEGER
    cartPosPR : INTEGER
    UF_Number : INTEGER
    UT_Number : INTEGER
    BEGIN
    -- Retrieve TP Arguments
    GET_TPE_PRM(1, data_type, resultPR, real_value, str_value, result)
    GET_TPE_PRM(2, data_type, cartPosPR, real_value, str_value, result)
    GET_TPE_PRM(3, data_type, UF_Number, real_value, str_value, result)
    GET_TPE_PRM(4, data_type, UT_Number, real_value, str_value, result)
    -- Get Robot's current JPOS
    currentJPOS = CURJPOS(0,0)
    -- Get Cartesian Position to Convert
    cartPos = GET_POS_REG(cartPosPR,result)
    UF_Ref = $MNUFRAME[1, UF_Number]
    UT_Ref = $MNUTOOL[1, UT_Number]
    -- Call Built-In Conversion Function
    POS2JOINT(currentJPOS,cartPos,UF_Ref,UT_Ref,0,dummyConfig,dummyArray,jointResult,status)
    -- Return Result to TP Position Registers
    SET_JPOS_REG(resultPR, jointResult, result)
    END K_POS2JNT
    Edited once, last by Davvoo22 ().
  • Big Thanks also from me to Davvoo22.
    Your program was not working in the beginning (Anyhow the GET_TPE_PRM command was not working). I had to do some minor modifications. I will post the program in case that other people have the same issues.
    I just recognized that i still have a problem if the UserFrame is 0.
    Do someone have any idea ?
    Greetings
    PROGRAM K_POS2JNT
    -- program vars
    VAR
    result : INTEGER
    status : INTEGER
    data_type : INTEGER
    int_value : INTEGER
    real_value : REAL
    cartPos : POSITION
    UF_Ref : POSITION
    UT_Ref :POSITION
    resultPR : INTEGER
    cartPosPR : INTEGER
    UF_Number : INTEGER
    UT_Number : INTEGER
    BEGIN
    -- GET_TPE_PRM(1, data_type, resultPR, real_value, str_value, result)
    -- GET_TPE_PRM(2, data_type, cartPosPR, real_value, str_value, result)
    -- GET_TPE_PRM(3, data_type, UF_Number, real_value, str_value, result)
    -- GET_TPE_PRM(4, data_type, UT_Number, real_value, str_value, result)
    resultPR = 1
    cartPosPR = 2
    UF_Number = $MNUFRAMENUM[1] -- get the actual UserFrame
    UT_Number = $MNUTOOLNUM[1] -- ge the actual ToolFrame
    WRITE('UF_Number: ', UF_Number)
    WRITE('UT_Number: ', UT_Number, CR)
    END K_POS2JNT
  • Thanks Davvoo22, the program is working for me.
    I observed that it does not work in some case.
    For exemple when :
    PR[2] = [360.0, 0.0, 280.0, 180.0, -90.0, 0.0]
    In this case POS2JOINT returns status = 15023 (=> MOTN-023 In singularity, The position is near a singularity point)
    Do you know how to solve this? Is there another built-in function or method to be able to convert any cartesian position to joint?
  • HI CPh,
    At the moment i am on vacations and can only check it if i am back in the company (25.).
    Did you include the Values to PR[2] by editing or are they come from the robot ? I guess it could be a problem with the config of the position in this case.
    Greetings
    Wiggi
  • Hi Wiggi,
    Sorry, for my late reply..
    If I understood well, yes I have written the values manualy in PR[2].
    Today I tried to record them with the teach pendant (Enable Singularity Avoidance : TRUE)
    I made a simple TPE program
    L PR[2] 100mm/sec FINE
    Then I opened the PR DATA menu, selected PR[2] and pressed on RECORD.
    The result is the same, I get the error 15023.
    (btw, PR[2] = [360.0, 0.0, 280.0, 180.0, -90.0, 0.0] (NUT000) is in fact == to PR[2] = [0.0, 0.0, 0.0, 0.0, 0.0, 0.0] in JNT coordinates)
    I guess there is nothing we/Fanuc can do to make the conversion work in case of a singularity, there is indeed an infinity of JOINT (J4,J6) values possible for this cartesian position.
    The program is working well for other positions :
    e.g. PR[2] = [360.0, 0.0, 280.0, 180.0, -85.0, 0.0] (NUT000)
    Enjoy your vacations!
    Edited 2 times, last by CPh ().
  • Hey Wiggi.. Yeah the problem you had was possibly because a lot of the time I assume that people will sent a register that is setup as an integer.. But sometimes those registers can turn into pesky floats if you aren't careful.
    You can check it on the routine:
    data_type indicates the data type for the parameter, as follows:
    1 : INTEGER
    2: REAL
    3: STRING
    To make the code more robust you should probably change it to this
    GET_TPE_PRM(3, data_type, Int_value, real_value, str_value, result)
    IF data_type = 2 THEN
    UF_Number = ROUND(real_value)
    ELSE
    UF_Number = int_value
    ENDIF
    But again your way is fine as long as you have the right frames active when you call the function.
    I'm afraid I don't know about the frame 0. Seems strange that it wouldn't work. I would suggest you just pick a random empty frame and use that instead.
    CPh
    I never really meant this function for other people when I wrote it so actually only spent about 2 hours writing this routine. Hence it doesn't check for any errors etc.
    For my application I got it working with the parameters as they were. If I was you though I imagine that you will need to tweak these parameters
    POS2JOINT (in_pos, uframe, utool, config_ref, wjnt_cfg, ext_ang, out_jnt, and status).
    I would potentially try using a cur_pos call and getting the current config you are in to replace my dummy variable I used.
    Also possible that it simply cannot be done. The singularity avoidance deliberately drives around the singularities and doesn't follow the correct path.
