Hello Kawasaki community,
Recently i've encounter an error P0158 "Missing BY" when trying to use block teach to do POS MOD on a Shift command motion line.
Example:
Line 1: LMOVE SHIFT (v25 by 0,10,0)
Line 2: LMOVE SHIFT (v25 by 0,10,10)
Line 3: LMOVE SHIFT (v26 by 0,0,100)
This was carry out on 6-axis robot, RS030N, E02 controller. The program was written in AS language, however the user of this automation is handle by an operator who is only experienced on using block teaching. The objective was to change the master position (v25), but the problem is that "MOD POS" function is unable to recognize this shift command.
Right now there is 2 propose solution to this problem:
1. Add in a GOTO label function within the steps to better ease for future changes.
Line 1: GOTO SKIP:
Line 2: LMOVE v25
Line 3: SKIP:
Line 4: LMOVE SHIFT (v25 by 0,10,0)
Line 5: LMOVE SHIFT (v25 by 0,10,10)
Line 6: LMOVE SHIFT (v26 by 0,0,100)
2. Creating a separate "Teach Utility Program" purely for teaching master positions.
Do share your opinion on this issue if you think there's some other methods we can utilize to make more convenient for the user.
Thank you!
Credits to kwakisaki for sharing his expertise to verify the error and providing a work-around solution.
