SPEED OVERRIDE
  • Hi!! I need to override the speed of the teach pendant when the robot is in auto. I tried to use a speedrefresh in a background task but don't work!
    If an operator drop the speed on th TP, i want it to back to 100%!
    Any ideas!?
  • VAR num nSpeedOride;
    nSpeedOride:=CSpeedOverride();
    WHILE nSpeedOride <> 100 DO
    TPErase;
    TPWrite "Speed Override is NOT 100%!!!";
    TPWrite "Program will run when override is set to 100%.";
    WaitTime 0.25;
    ENDWHILE
    You should also make sure the the system parameter ALLDEBUGSETTINGS is TRUE, so that when switching from teach into auto the speed automatically gets reset to 100%.
