Fanuc eStop status
  • TexDino
  • June 11, 2019 at 12:52 PM
  • TexDino
    38
    how can I check eStop status of robot? I want to use it in bg logic to turn off pneumatic valve.
    Is there a place this information can be found normally? I have access to Fanuc manuals, but have no idea in which to look for this. I also need the same information for fence open and running in auto mode, dead man switch and stuff like that.
    I can't use just "Alarm" status on UOP since I need it working to solve some of the problems
    If my posts are dumb please tell me so I can post better ones :smiling_face:
  • tonygast
    244
    • June 11, 2019 at 1:16 PM
    Menu>0>6>TYPE>Config
    Images
      • 54.96 kB
      • 669 × 444
      • 46
    Files
    E stop Capture.JPG_thumb 23.15 kB – 113 Downloads
    Oh, well
  • scotty
    43
    5
    497
    • June 11, 2019 at 3:03 PM
    Better to install safety relays, then you can repurpose the signals somewhere else.
  • Nation
    Typical Robot Error
    542
    1,924
    • June 11, 2019 at 4:25 PM
    Depending on what you are doing, a safety relay might be warranted, but if it is something like a glue gun, I don't think one would be needed.
    Regarding the deadman, fence status, and other robot safety statuses, you can interconnect those to DOs via the interconnect menu under IO->F1 |TYPE|-> 9 Interconnect-> F3 [SELECT]-> 5 ES->DO
  • TexDino
    38
    • June 13, 2019 at 7:05 AM
    Thanks all. I tried this and it works now perfectly.
