  4. Kawasaki Robot Forum
Kawasaki FS030L no cotrol power
  • Smajic Jasmin
  • June 3, 2019 at 9:24 AM
  • Smajic Jasmin
    28
    Greetings to you all at this amazing forum, I've been reading your experiences for couple of days, you are amazing!
    We got Kawasaki robot model FS030L-B in my company last week, it was taken form production while it was functioning, but that was at least 3 years ago ( maybe even more). So when we plugged it in first thing we hear is some sound coming from controller C41F-A020, something like "tump" :hmmm: we checked all switches and everything is on. What we could locate is that sound is coming form lower side of controller. And control power light is turned off.
    After Turn on touch panel turns on and we got some errors which we solved by reading this forum including error based on encoder batteries and encoder zeroing.
    Next we tried to turn Motor power on but it just blinks. In the touch panel e-stop is always active even when we reset both e-stop buttons so these are not activated and we still have e-stop active on touch panel.
    Reading your forum I came across dip switch 8 method but I wanted to check with you guys before we try that. Or if you have diagram for jumper for this controller that would be helpful.
    Let me know what you think. :help:
  • kwakisaki
    694
    4,770
    • June 3, 2019 at 10:55 AM
    Welcome to the forum........ :beerchug:
    The 'tump' you hear is the inrush to the transformer (which is normal).
    So you have power, lights but no action yet.
    Please do not use dipswitch 8 method...this will empty the controller of ALL of it's current settings and possibly create more problems, so let's try and resolve your issues first.
    You mentioned Emergency Stop is indicated even though both Operation Panel and Teach Pendant Estops are ok.
    Motor Power Blinking means Estop circuit is broken.
    Check out the attached External IO Manual - A-27 gives example for TB2 Connections, so try and make same.
    Files
    90204-1008DEF_C3x-C4x-C70-C80_External_IO_Signals.pdf 2.27 MB – 17 Downloads
    Edited once, last by kwakisaki (June 3, 2019 at 11:07 AM).
  • Smajic Jasmin
    28
    • June 13, 2019 at 3:22 PM
    Sorry for not responding, we went on holiday after we talked last time.
    I just got an opportunity to try what you have sent me, and this is the situation. I have removed and added all jumpers as on scheme, now we can turn on motor power it lights on and stays on but control power is still not on. After I try to move axis it triggers error code that motor power is off.
    I am not sure about 1-2 should this be connected with jumper or to external power, or left open?
    I have attached some photos. What should we do next?
    Thank you very much.
    Images
      • 181 kB
      • 1,145 × 2,048
      • 7
      • 277.04 kB
      • 2,048 × 1,152
      • 10
      • 147.76 kB
      • 1,728 × 972
      • 14
    Files
    62362022_2104266419871384_8941643957721366528_n.jpg_thumb 20.39 kB – 43 Downloads 64206880_610660349443733_6678407938912026624_n.jpg_thumb 21.43 kB – 43 Downloads 64416212_575378746321783_7198813453832683520_n.jpg_thumb 33.57 kB – 43 Downloads
  • kwakisaki
    694
    4,770
    • June 13, 2019 at 3:51 PM
    OK, so you have progress then.
    I am a little confused when you refer to 'Control Power'.
    - Control Power is for Controller Power (This is the lamp that is above the hour meter).....this is just a lamp/bulb and has no effect if bulb is popped/missing.
    - However, I assume this is not what you mean as you have error code -1308 displaying.
    Referring to your TB2 Connections, I still think there are some links incorrect and missing, so please:
    - 1 and 2 and 3 and 4 should be left as is, if there was a problem here, Controller would not power up.
    - Do you have small signal relay fitted to left of TB2 and if so, is this secure in place, loose or missing?
    - remove link between 13 and 14.
    - add link between 25 and 26 (external trigger ch1)
    - add link between 27 and 28 (external trigger ch2)
    Try this again.
    If you still receive error, then power off and check cables and contacts on auxiliary of K1 and K2.
    Edited once, last by kwakisaki (June 13, 2019 at 3:53 PM).
  • Smajic Jasmin
    28
    • June 13, 2019 at 4:58 PM
    We do thank You.
    we have solved this now when I click trigger/deadman switch we hear click in robot arm but no movement in teach mode and we have error code 1337. Which says Two MC lines are not consistent.
    How can we resolve this?
  • kwakisaki
    694
    4,770
    • June 13, 2019 at 6:28 PM
    Hmmmm......not an easy error to locate, could be anything on the safety circuit that causes this.
    Usually points to one of the channels of the safety circuit is not being seen correctly.
    - Can you make sure all MCB are in correct position (F2 and F5).
    - Do you know if there used to be an axis limit switch fitted to arm (maybe on JT2 or JT3).
    - Can you remove back cover of FS30 and look at enclosed circuit board and post image of all connections.
    - When you enable the deadmans, do hear a click and clunk inside the controller.
    - Can you look at operation of K1,K2 and K3 when you press deadmans (door has to be open with power so be careful).
    - Can you locate 1HY board (this is on left side of controller towards back and down) and provide status of LED's.
  • Smajic Jasmin
    28
    • June 13, 2019 at 10:00 PM
    Robot is moving :biggrins::cheer:
    So we made a lot of progress today. We can move robot in teach mode, but when we try to run a program we get 1337 error again :hmmm:
    - I'll check F2 and F5
    - I dont have that information how can I check this?
    - By back cover you mean where power cables are pluged in?
    - Yes, I can hear a click in controler and in robot
    - K1, K2 and K3 are working
    - 1HY board is plugged in and working
    As I have stated before this robot was used in combination with other machines so we have one extra board in SLOT 1 which is connected to cables that are no longer in use. ( White cables) Could this be a cause of our problem? Also, I would like to remove these cables as these are large in size and we don't use those. Can I remove this extra board? Is there some proceudre for doing this?
    Images
      • 49.06 kB
      • 480 × 864
      • 8
    Files
    62590560_2067066580262089_7367347553915895808_n.jpg_thumb 24.8 kB – 40 Downloads
  • kwakisaki
    694
    4,770
    • June 13, 2019 at 10:12 PM
    So what I wrote earlier is not relevant 100% now that you can move it in Teach Mode.
    Whether you are in Teach or Repeat, the same power distribution components are used.
    F2,F5,K1,K2,K3 and back cover of robot (where cables plugged in)............so need to check these.
    The board you are referring to is just the IO board, so this would not interfere with robot motion.
    - Top Connector is Outputs.
    - Middle Connector is Arm IO.
    - Bottom Connector is Inputs.
    If you remove this board, you will receive No.1 Board IO is not installed error each time you power on.
    - You will have to tell Robot no IO is fitted and there is a small procedure for this.
    - You could just remove the cables of CN2 (top) and CN4(bottom) and leave the board in instead.....it will do no problem.
    Ok, so in Repeat mode is where you get this error.
    - Check jumpers are firmly connected in TB2 (15-16 and 17-18).
    - Check wiring to and integrity of Teach/Repeat Switch.
    - Check CN2 connector is firmly connected to 1HP board.
    At least you are making progress.......... :top:
  • Smajic Jasmin
    28
    • June 14, 2019 at 3:05 PM
    Yes we are making a lot of progress.
    - I have checked jumpers and these are fine
    - CN2 connector is also fine
    About Teach/Repeat Switch
    When we turn from teach to repeat we lose motor power and trigger 1337 error. So I have checked switches brown NC and black NO on top side so black switches are working as described NO but on lower side brown ones front and back are NC but middle one is NO allways so we will try some contact spray.
    Photos are attached. Is this causing our problem?
    Images
      • 56.28 kB
      • 960 × 540
      • 6
      • 57.06 kB
      • 960 × 540
      • 8
    Files
    62591755_442517669924748_938653050862567424_n.jpg_thumb 22.17 kB – 40 Downloads 64290213_2380354922180356_4009251447106437120_n.jpg_thumb 21.31 kB – 40 Downloads
  • Smajic Jasmin
    28
    • June 14, 2019 at 4:30 PM
    This is an update,
    I have resolved issue with switches so these are now working properly. But I still get 1337 when I switch from teach to repeat.
  • Alexandru
    49
    407
    • June 14, 2019 at 4:33 PM
    • #11
    Try to switch from teach to repeat without motor ON.
    It is normal to have motor OFF when you switch from teach to repeat.
    Can you reset this error?
  • Smajic Jasmin
    28
    • June 14, 2019 at 4:48 PM
    • #12
    We have tried that and we cannot reset error 1337.
  • kwakisaki
    694
    4,770
    • June 14, 2019 at 6:41 PM
    • #13
    Hmmm.
    When you switch between Teach and Repeat, Controller should ALWAYS remove motor power.
    Are you saying when you go from either Teach => Repeat or Repeat => Teach, motor power is turning on by itself?
  • Smajic Jasmin
    28
    • June 14, 2019 at 7:13 PM
    • #14
    Yes when change from teach to repeat motor power does go off. But even if we turn motor power off by e-stop reset then change to repeat few seconds after turning the key we get error 1337. Then we turn key back to teach and turn motor power on and it works fine. :hmmm:
  • Smajic Jasmin
    28
    • June 14, 2019 at 7:28 PM
    • #15
    My bad. Motor power is not turning on by it self when you go from teach to repeat and back. So when we activate repeat without touching anything elese after couple of seconds we get 1337 error.
  • kwakisaki
    694
    4,770
    • June 14, 2019 at 8:11 PM
    • #16
    Well, if you said this was working before (albeit 3 years ago), then I think the logical process with this is not to mess around with settings in software etc.
    - I still think this is pointing to a problem from that Teach and Repeat Switch.
    - I would take a few notes/pictures and take it all apart as this is the only part of the circuit that relates to dual channel function swap over.
    I'll have to try and dig out some schems and see where else to look over the weekend........
    Try the attached procedure and see if this setting masks out the problem JUST AS A TEST....
    Images
      • 33.45 kB
      • 1,246 × 271
      • 15
    Files
    Capture.PNG_thumb 5.12 kB – 43 Downloads
    Edited once, last by kwakisaki (June 14, 2019 at 8:15 PM).
  • Smajic Jasmin
    28
    • June 14, 2019 at 9:45 PM
    • #17
    Thank You.
    I will check this tommorow morning. We took this switch appart today when we had issue ti NC/NO but we can do it again tommorw.
    One more thing that I have noticed when I try to run program in check mode in teach nottingh happens but when I go to keyboard menu it says "Program Held". Also I have conneced to robot through terminal and when I try to run a program in check mode in terminal I get message Program hold. Can this be related? I'll attach photo from keyboard menu
    Thank you once more
    Images
      • 3.25 MB
      • 4,608 × 2,592
      • 15
    Files
    20190614_195307.jpg_thumb 19.8 kB – 45 Downloads
  • kwakisaki
    694
    4,770
    • June 14, 2019 at 10:02 PM
    • #18
    The check mode issue will not be connected to your problem.
    When you say 'run program in check mode'......what are you doing precisely - Can you describe what you are doing exactly?
  • Smajic Jasmin
    28
    • June 14, 2019 at 10:46 PM
    • #19
    1. I load a program from program list. We have lot of programs, but also we have simple program we wrote to move one joint. As described in AS language manual.
    2. Then I click check mode. Turn motor power on hold deadman switch and then I click on arrows to move down through program lines. Lines move but robot doesn't.
    3. After this I go to keyboard and I see message program held. Also when connected KRTerm as I click on arrows with holding deadman we get message on terminal "program hold."
    Are we doing something worng here?
  • kwakisaki
    694
    4,770
    • June 14, 2019 at 11:39 PM
    • #20
    Ah ok......
    Check Mode toggles between Once(Single Step) and Continuous(Step after Step).
    You also need to press Check Forward whilst holding deadmans.
    Images
      • 86.55 kB
      • 648 × 648
      • 10
    Files
    Capture.PNG_thumb 19.69 kB – 43 Downloads
    Edited once, last by kwakisaki (June 14, 2019 at 11:50 PM).
