Greetings!
I am currently working on a few new spot weld cells cycle times. One area that we could save a couple of seconds is in between program calls (from within main program, not PNS call from PLC) where the robot comes to a stop and does not follow a continuous path. Is there a way to get the robot to anticipate into the next program where it is going to go?
An example would be a standard pedestal spot welder / material handler.
1. PICK
2. WELD
2a. Run TIPDRESS (after weld, while dropping)
3. DROP
I know one option would be to put it all in to one program, but that would eliminate our ability to run tip dress in the background because the main program and tip dress program would both need Group 2.
Thanks,
Steven
