Operating a Weld gun without a Robot
  • ToloTester
  • May 17, 2019 at 6:22 PM
  • ToloTester
    How would I setup my Fanuc Controller (J-30iB with StopTool) to operate a weld gun without a robot. In the Controlled Start maintenance screen it shows there is a M-10ia/10M in group 1 and it will not let me clear that out. Am I in the right place?
    Thanks,
  • Nation
    Typical Robot Error
    523
    1,903
    • May 17, 2019 at 9:42 PM
    I am not sure this would work, but could you just disable group motion (under the test menu) and then run the torch? It is a bit out of my wheel house, as I don't work on welders that often.
  • ToloTester
    • May 17, 2019 at 10:28 PM
    Disabling the group in the test menu didn't fix the problem. I am still faulted out with SRVO-075 pulse not established on Grp 1 axis 1. I think the controller is expecting a robot to at least be plugged in. I literally have the J-30iB controller without a robot at all. There has to be a way to just disable group 1 at a lower level.
    Thank for the help.
  • oakleyas
    45
    • May 18, 2019 at 9:16 AM
    Weather you use the robot or not, it still needs to be connected.
  • tonygast
    244
    • May 28, 2019 at 4:13 PM
    Try setting the axis order for 1-6 to 0
    Images
      • 52.56 kB
      • 614 × 788
      • 20
    Files
    axis order.JPG_thumb 19.97 kB – 32 Downloads
    Oh, well
