KRC4 ForceTorqueControl
  • TheFatRat
  • May 16, 2019 at 8:28 AM
  • TheFatRat
    18
    I use F/T Sensor: Delta IP60 (ATI Net F/T) with a robot KUKA KR 210 R2700 extra with software KUKA.ForceTorqueControl.
    This complex is designed for processing the edges of parts, for this using a different tool. The tool we use has a different weight.
    Is it possible using F/T Sensor calculate weight, mass center on a robot.
    Thanks for the help.
    SkyeFire
    1,052
    9,427
    • May 16, 2019 at 10:28 PM
    I believe there is a process in the Force-Torque manual for doing this. I've never used it myself.
  • Roboformer
    19
    • May 17, 2019 at 10:08 AM
    With ForceTorqueControl comes a program called LoadDataDetection. I have never used it for its intended purpose but based on the name it might do the trick.
  • TheFatRat
    18
    • May 17, 2019 at 10:40 AM
    I dont have this program on the robot.
    SkyeFire
    1,052
    9,427
    • May 17, 2019 at 5:29 PM
    As shown in the FTC manual (Section 7.4): FTCtrl_LDD.SRC. It should be in the TP/FTCTRL/ directory.
    If it's missing, you can find in in the FTCTRL installer directory under D:/KUKA_OPT.
  • TheFatRat
    18
    • May 18, 2019 at 8:11 AM
    Quote from SkyeFire
    Thank you, I have already found this function and it correctly calculates.
    But I could not suggest an algorithm for calculating it, find FTCtrl directory C:/KRC/TP/FTC, I cant understand how the program calculates the data received.
  • panic mode
    1,280
    13,083
    • May 18, 2019 at 6:45 PM
    many people do not understand how microwave ovens, cellphones etc work. that does not stop them from using those things. are you trying to make your own LDD?
  • TheFatRat
    18
    • May 19, 2019 at 7:11 AM
    Quote from panic mode
    Yes, I can know the forces that act in each position and know the positions of the robot, but I cant compare these data to get the mass and center of gravity.
    SkyeFire
    1,052
    9,427
    • May 20, 2019 at 3:15 PM
    You are using a 6DOF load cell, correct? As long as you have all three forces and torques from the load cell, this should be an exercise in statics analysis. Specifically, cantilever beam force and torque. https://www.engineeringtoolbox.com/cantilever-beams-d_1848.html
    Knowing the exact relationship between the gravity vector and the load cell origin would be necessary. To simplify the math, it would help to align one axis of the load cell with gravity, record the forces and torques, then repeat with another axis aligned with gravity. You could probably get enough data from just one measurement, but doing two would allow for cross-checking.
    The Force you see along that axis should be the whole mass of the payload, times gravity. So your payload mass should be the Force in Newtons divided by 9.8. Likewise, the Torque should be the Mass * gravity * the distance from the load cell origin to the payload center of mass.
  • panic mode
    1,280
    13,083
    • May 20, 2019 at 7:50 PM
    Load identification is a nice but rather involved exercise that requires dynamic system, data collection and processing that will likely make your head spin.
    Determining static load such as mass can be simpler.
    But if LDD function is part of your F/T, isn't there a way to simply call that function?
  • robguy1993
    • June 27, 2019 at 8:07 AM
    • #11
    Hello guys,
    I need ForceTorqueControl package. Please help me..
  • Fubini
    278
    1,888
    • June 27, 2019 at 12:32 PM
    • #12
    There you go: call kuka. They sell it.
    Fubini
