Hi
Question regarding network topology in an cell with several IV cameras and robots.
Normally we connect every unit to the same switch to be Abel to connect to them all from one port.
As I know IV cameras does only work throw service port/LAN2 on the controller. So connecting everythink to same switch will overlap the ip addresses because LAN2 has an static ip address that can't be change.
An other option is to connect IV camera directly to the LAN2 port on the controller and controller wan port to the cell switch. Limitation for this alternative is that we can't access the cameras throw wan port for debugging.
So is there any convenient way to set up the topology for this kind of cell?
Br:zicki
