Hello
Could you please help me with config files for ext axis?
So i want to connect DC2T with a drive inverter for one external axis
And Use measurement system 2 for 2d SMB
I want to connect only 1 axis first
And dont quite understand what file should i install
As I understand - i should install MN1M2D1 (Logic axis 8, meas syst 2, node 1(this means that i should connect resolver to node 1?), Drive System 1 unit position 0 (what does it mean?), node: 2(what does it mean?))
then i will add parameters of my motor, but is MN1M2D1 right file for my configuration?
Thank you
