Hi All,
My question is: How can I modify the "Power-off delay time" to a larger number. eg: 240s.
KSS8.5 System integrator manual Section 4.6.1.
I am currently on KRC4 KSS8.5 (KSS8.3 should be similar).
I am looking at the 'Power-off delay time' (Under the Main Menu > Shutdown).
I was able to run a program in EXT AUT, then switch the mains off for 3s, (causing Stop 0) then switch mains back on and restart my application using ConfMess, DrivesOn, ExtStart. (Emulating a recovery program with the use of a UPS).
I have found a number of timeouts within C:\KRC\SERVICES\Powermanagement\PMService.config, however I thought I may ask before playing around with these parameters. Thanks!
