Stop the move with reed sensor
  • the_daw_
  • April 29, 2019 at 1:48 PM
  • the_daw_
    HI PROGRAMMERS! :yesyesyes:
    Let me to ask you one default thing what I don't know ...
    I want to tighten a cap with J6. I made a move that turns 720 degrees. I have a clutch on the gripper with a pneumatic cylinder and when the target torque was built I want to stop this movement with the reed sensor of the clutch's cylinder. How can I do that?
    I tried it with SKIP command but it didn't work, because it checked the condition of the reed sensor before the movement.
    :help: :merci:
  • Fabian Munoz
    134
    Articles
    1,517
    • April 29, 2019 at 3:42 PM
    hi the_daw_
    Welcome to the robot forum
    I dont exactly understand what you're doing
    So, you have a cap held by a gripper. I'm guessing the cap is at 0,0,something from the flange (centered) and when you rotate axis 6 the cap rotate. Also you program a motion ( i guess J) to rotate,
    This gripper has some kind of torque read out , i guess
    I also I understand you need an input to stop rotation
    I just dont understand the cylinder and reed switch set up
    A picture will be great
    Retired but still helping
  • scotty
    43
    5
    497
    • April 29, 2019 at 4:18 PM
    If SKIP condition doesnt work in your case, you can do next:
    while loop with increment move on your J6.
    LBL[1]
    J PR[*] %speed INC
    IF DI[*] = OFF, JMP LBL[1]
    in this case robot will do incremental move that is listed in PR[*] while DI is off.
    Example attached.
    Images
      • 18.52 kB
      • 673 × 385
      • 23
    Files
    Capture111.PNG_thumb 13.33 kB – 55 Downloads
Users Viewing This Thread
  • 1 Guest
