I have a KRC4 that will not move and there is a mastering request for A4, A5 and A6. I can't master these axis because we can't get the robot to move at all. Any thoughts?
Robot will not move
Mhawryluk -
April 27, 2019 at 7:35 PM -
switch to axis specific coordinate system
Done and same. Will not move.
make sure all safety is ok, use T1 mode and hold enabling switch
Yeah that was also done and that is not working. This is in the same cell as the robot that had the issue with the encoder cable; however, a different robot.
Done and same. Will not move.Will not move = ($MOVE_ENABLE==FALSE)
Check your PLC has not registered the error and is stopping the robot.
if the encoder is related to external axis, create a copy of WoV project and remove external axes. then you should be good to go.
otherwise, check messages and send KRCDiag to kuka call center in MI. -
Pulled the KUKAdiag and sent it in. Came back needing a new wiring harness due to a short in the axis 4 cable causing robot to lose position and mastering for a4/a5/and a6. We now have KUKA support on site to change out the wiring harness and get us back up and running.
