I'm having issues with a Kuka KMR omnimove with attached LBR iiw 14 R820 SC FLR. On initial start up its giving the error of:
Safety Control
Position Sensor not mastered (K2: A1,A2,A3,A4) - I believe these are the mecanum wheels
Position Sensor not referenced (K1: A1,A2,A3,A4,A5,A6,A7) - I believe this is the arm
Error reading offsets of mastering notches for position referencing(Kinematics K2)
I can connect the radio control unit and the KMR receives the input but still no movement. Moving the KMR with the pendent is possible but only for about 5cm before it cuts out.
Ive tried to perform a brake test on the KMR only to be met with the following error:
Generic device error
Bus Interface error of Thin4MAdpter_KMP.BusIF
Common Servo error (ID8, ID9)
Error: Common Brake error( Servo, Servo)(ID8, ID9)
Its running Kuka sunrise.OS 1.14.1.15. The Hardware, firmware and embedded all have version errors 0x98110005. Its fresh out of the box. Hopefully this is all the info required.
Any help on this would be greatly appreciated.
