SCIO-016 Prog uses un-installed option
  • Hello. I'm afraid this is going to be a question with a wide array of causes and I am not able to give enough info.
    I programmed a weld program via TP. Once finished, I backed up the TP file to a computer and it was deleted from the controller. When I tried to load it to Roboguide, I got the SCIO-016 Prog uses un-installed option alarm. I then tried loading it back to the controller and I got the same message. I did not disable any options as far as I am aware. I cannot think of any reason I would be getting this. Also, is there no way to at least load the program to Roboguide without getting this error?
    RJ3iB - M-16iB 20
    Software V6.10
    I appreciate any ideas or insight. Thanks
    Edited once, last by stainless_steele ().
