Hi, Guys!
In my application it is a 3D Vision system for robot guiding (ABB IRB).
The Vision system gives the position data in X,Y,Z rX,rY and rZ.
When the object has an rZ=0 - everything is fine.
My problem is when rZ differs from 0.
For instance, if rX=0, rY=10 and rZ=90, this result in rotation around X - instead of Y.
I'm sure this is a common case for robotics, but I can't find any information about this topic.
What is the formula/function to handle this case?
I'm using a Siemens Simatic S7-1500 Controller in my system (sending position values to Robot by ProfiBus), so if anyone has an application example with Simatic S7, it would be perfect. I guess I need to modify rX/rY from the vision system before sending pick position to robot.
Thankful for any help.
/hanho
