Help needed for understanding palletizing function
  • I am trying to understand the logic of palletizing function and copied this sample code from a topic posted 3 years earlier.
    My questions are:
    1. What's the difference of P[1,1,1] and P[BTM] in the palletizing configuration section? I thought in the beginning, these two points should be the same when the palletizing was initially set up.
    2. Does PAL_1[BTM] automatically loop through all the points of locations governed by ROW, COLUMN and LAYER? I did not see any loop function in the main body and wonder how all the points can be reached?
    Thanks!
    /PROG O1050
    /ATTR
    OWNER = MNEDITOR;
    COMMENT = "PL[1]_Load1";
    PROG_SIZE = 1792;
    CREATE = DATE 14-10-27 TIME 18:30:28;
    MODIFIED = DATE 16-09-02 TIME 15:06:02;
    FILE_NAME = ;
    VERSION = 0;
    LINE_COUNT = 27;
    MEMORY_SIZE = 2212;
    PROTECT = READ_WRITE;
    TCD: STACK_SIZE = 0,
    TASK_PRIORITY = 50,
    TIME_SLICE = 0,
    BUSY_LAMP_OFF = 0,
    ABORT_REQUEST = 0,
    PAUSE_REQUEST = 0;
    DEFAULT_GROUP = 1,*,*,*,*;
    CONTROL_CODE = 00000000 00000000;
    /APPL
    Palletizing[1];
    CONFIG:
    PALLETIZING-B_1 "1" ;
    TYPE = PALLET ;
    INCR = 1 ;
    PAL REG = 1 ;
    ORDER = RCL ;
    ROWS = [7] ;
    COLUMNS = [5] ;
    LAYERS = [1] ;
    AUXILIARY POS = [NO ] ;
    APPR = 1 ;
    RTRT = 1 ;
    BOTTOM:
    P [1,1,1]{
    GP1:
    UF : 0, UT : 1, CONFIG : 'F U T, 0, 0, 1',
    X = 769.761 mm, Y = -501.843 mm, Z = 83.783 mm,
    W = -89.662 deg, P = 1.547 deg, R = -144.483 deg
    P [7,1,1]{
    GP1:
    X = 512.812 mm, Y = -146.700 mm, Z = 83.590 mm,
    W = -89.659 deg, P = 1.548 deg, R = -144.483 deg
    P [1,5,1]{
    GP1:
    X = 555.883 mm, Y = -656.656 mm, Z = 83.620 mm,
    ROUTE:
    P [A_1]{
    GP1:
    X = 769.717 mm, Y = -501.841 mm, Z = 125.534 mm,
    P [BTM]{
    GP1:
    X = 769.759 mm, Y = -501.840 mm, Z = 83.839 mm,
    P [R_1]{
    GP1:
    /APPL
    /MN
    1: !*******************************! ;
    2: !-------------------------------! ;
    3: !--------Drawer1 Loading--------! ;
    4: !----------PL[1] TOP1-----------! ;
    5: !-------------------------------! ;
    6: !*******************************! ;
    7: UFRAME_NUM=0 ;
    8: UTOOL_NUM=1 ;
    9:J P[1] 50% CNT50 ;
    10: ;
    11: LBL[200] ;
    12: UFRAME_NUM=5 ;
    13: UTOOL_NUM=1 ;
    14: CALL O9992 ;
    15: PALLETIZING-B_1 ;
    16:L PAL_1[A_1] 1000mm/sec FINE ;
    17:L PAL_1[BTM] 800mm/sec FINE Offset,PR[50] ;
    18: CALL HAND1CLOSE(1) ;
    19:L PAL_1[R_1] 1000mm/sec FINE ;
    20: PALLETIZING-END_1 ;
    21: R[15]=R[15]+1 ;
    22: IF R[18]>=R[17],CALL O9999(40) ;
    23: IF (F[10:OFF]),JMP LBL[200] ;
    24: ;
    25: UFRAME_NUM=0 ;
    26: UTOOL_NUM=1 ;
    27: END ;
    /POS
    P[1]{
    GP1:
    X = 262.411 mm, Y = -323.818 mm, Z = 222.908 mm,
    W = -88.866 deg, P = -.408 deg, R = -144.084 deg
    /END
