The application is for rotomold. That(induction motor) is what we are using at the moment but a servo motor would give us better control option as in braking control, position control etc. At the moment it is based on timing.
Fanuc robot multitasking
Arvi -
March 21, 2019 at 4:31 AM -
Thread is Resolved
Hi
I figured out how to add Group 2 on the controlled start under robot library. But it does not allow me to add the extended axis under Group 2. It Gives me "Invalid Subscript" error. Can anyone guide please.
Thanks -
I assume you attempted a S/W install under controlled start
Check what other options are installed in your systemThe system will only allowed you to install the libraries according to your installed options
For example you can add basic positioner if you have that optionThe basic positioner will be added as group 2
Then you configured the axis as a basic positionerI think this is the path to reconfigured the 7th axis as a separate group
Could you please post what option you have
Hi Robotero
I had the Positioner option installed and figured out how to assign the external axis(7th axis) under group 2. Achieved what i was trying to.
Big thanks to everyone who has supported me with all their experience and knowledge.
thanks again. -
