Hello
Is it possible to use the instruction "MoveJ" in this Robot? If it's possible, how can I enable the function (cannot find in the Inform List).
Thank you!!
Hello
Thank you!!
Press the MOTION TYPE key in the bottom left hand corner of the pendant.....
Hello roboprof,
Thank you for your reply.
The only Motion Types I get is MOVL or MOVC. Do I need to get any Parameter/Function active to allow me to use this kind of move?
Thank you!!
Hello
you couldn't use MOVJ instruction in this robot model. (delta robots)
only the MOVL and MOVC are available.
don't try to use MOVJ in this robot because it can hurt to robot.
Helloyou couldn't use MOVJ instruction in this robot model. (delta robots)
Hello asgary64,
Thank you very much for your reply anda I'll not use MOVJ in this kind of Robot!
Thnk you again!
