MODULE MOD1
! Customer: Precix
! Robot System: IRB 120
! Program Written by:
! Author: Nur Fatihah
! Date Created: 08/03/2019
! Last Modified: 00/00/0000
VAR socketdev Server_Socket;
VAR socketdev Client_Socket;
VAR bool listening:=TRUE;
VAR string Receive_string;
CONST string IP_ComAddress:="192.168.125.1";
!"192.168.125.1";
CONST num Port_Number:=0004;
VAR num retryNo:= 0;
VAR socketstatus state;
VAR string Send_String;
VAR bool ok;
VAR num modNum;
VAR num check;
! Procedure main
! A:
! SocketClose Server_Socket;
! SocketClose Client_Socket;
! Receive_string:="";
! SocketCreate Server_Socket;
! SocketCreate Client_Socket;
!! SocketConnect Server_Socket,"192.168.125.1",2000;
! SocketConnect Server_Socket,IP_ComAddress,Port_Number\Time:=5;
! SocketAccept Server_Socket,Client_Socket;
! TPWrite "Reader 1 Connect Success";
! state:=SocketGetStatus(Server_Socket);
! IF state=SOCKET_CONNECTED THEN
! Robot_Receive1;
! ELSEIF state=SOCKET_CONNECTED THEN
! Robot_Receive1;
! ELSE
! TPWrite "unknown status";
! GOTO A;
! ENDIF
! ERROR
! IF ERRNO=ERR_SOCK_TIMEOUT THEN
! TPErase;
! TPWrite "Socket Timeout, Retry ";
! TPWrite "Socket Timeout, Check Connection IP";
! WaitTime 1;
! retryNo:=retryNo+1;
! IF retryNo>=5 THEN
! TPErase;
! TPWrite"Socket Connection failed after 5 retry";
! retryNo:=0;
! WaitTime 5;
! ExitCycle;
! ELSE
! RETRY;
! ENDIF
! ELSEIF ERRNO=ERR_SOCK_CLOSED THEN
! TPWrite "Socket Closed, Retry... ";
! WaitTime 1;
! Stop;
!! ELSE
!! TPWrite "ERRNO = "\Num:=ERRNO;
! ENDIF
! ENDPROC
PROC ConnectToServer()
A:
Receive_string:="";
WaitTime 0.2;
! SocketBind Server_Socket,IP_ComAddress,Port_Number;
TPErase;
TPWrite"Waiting for computer to response...";
! SocketListen Server_Socket;
! WHILE listening DO
SocketConnect Server_Socket,IP_ComAddress,0004;
! TPErase;
! TPWrite "Connection Success";
! ENDWHILE
state:= SocketGetStatus(Server_Socket);
TPWrite "Reader 1 Connecting Success";
Robot_Send;
bQcheck:=FALSE;
Robot_Receive1;
Robot_Send;
! Robot_SendInner;
!Robot_Receive;
bQcheck:=TRUE;
GOTO A;
ELSE
TPWrite"Unknown socket status";
Stop;
ENDIF
ERROR
TPErase;
WaitTime 1;
retryNo:=retryNo+1;
IF retryNo>=5 THEN
TPErase;
retryNo:=0;
WaitTime 5;
ExitCycle;
ELSE
RETRY;
ENDIF
WaitTime 1;
Stop;
! ELSE
!! GOTO A;
ENDIF
ENDPROC
PROC Robot_Send()
SocketSend Server_Socket\Str:="Check1";
TPErase;
WaitTime 1;
retryNo:=retryNo+1;
IF retryNo>=5 THEN
TPErase;
retryNo:=0;
WaitTime 5;
ExitCycle;
ENDIF
WaitTime 1;
Stop;
! ELSE
!! GOTO A;
ENDIF
ENDPROC
PROC Robot_Send2()
SocketSend Server_Socket\Str:="Check2";
TPErase;
WaitTime 1;
retryNo:=retryNo+1;
IF retryNo>=5 THEN
TPErase;
retryNo:=0;
WaitTime 5;
ExitCycle;
! ELSE ERRNO=ERR_SOCK_CLOSED THEN
! WaitTime 1;
! Stop;
ENDIF
! ELSE
!! GOTO A;
ENDIF
ENDPROC
PROC Robot_Receive1()
SocketReceive Server_Socket\Str:=Receive_string\Time:=5;
WaitTime 0.1;
ok := StrToVal(Receive_string,modNum);
TPErase;
WaitTime 1;
retryNo:=retryNo+1;
IF retryNo>=5 THEN
TPErase;
retryNo:=0;
WaitTime 5;
ExitCycle;
ELSE
! RETRY;
ENDIF
WaitTime 1;
Stop;
! ELSE
!! GOTO A;
ENDIF
ENDPROC
PROC Robot_Receive2()
WaitTime 0.1;
ok := StrToVal(Receive_string,check);
TPErase;
WaitTime 1;
retryNo:=retryNo+1;
IF retryNo>=5 THEN
TPErase;
retryNo:=0;
WaitTime 5;
ExitCycle;
ELSE
! RETRY;
ENDIF
WaitTime 1;
Stop;
! ELSE
!! GOTO A;
ENDIF
ENDPROC
i>this program should connect between robot and computer through tcp/ip.
II>after robot connect. it should appear "connecting success".
III> robot wait until receive computer send model 1,2,3 or 4
IV> robot run program pick and place and when at check 1 and 2 other send/receive happen to check part ok or bad part.
Based from this program i want ask few question:
1. when i run the program , it stuck at SocketConnect few second then it appear socket time out and if i run it again it just said waiting computer response. how i can fix it?
2. ip address and port number.. where i can get it? and ipcomaddress should be ip computer or robot address?
3. if anyone have other sample program for socket communication using tcp/ip and it in very simple way to understand.. can i have it for reference
tq..
