Hello, i have a problem with a Fanuc robot S-420 iF , with a RJ2 Controller, first, the robot was working completly fine, next day didnt even turn on the controller, i dont know if here happened a voltage drop on the lines, i checked voltages, everything, so i decided to replace the power supply unit (i had a replacement here). After that the robot turn on normally, but i have this issue with the hold function, because all the time the led state of the pendant ¨HOLD¨ it is turned on, so i can´t perform a cycle start to make the robot work, if i put it in Manual mode (T2) , the Hold light stills on, and if i try to jog the robot, the pendant shows this two errors:
- JOG-005 CAN NOT CLEAR HOLD FLAG
- SYST-001 HOLD BUTTON IS BEING PRESSED
I checked the HOLD button from the operator panel, it is working fine, closing and opening the contacts, and disabled the UI signals on the robot (because i am using this signals from a PLC to the robot), but even doing this i still have this message.
I have changed:
- Power supply unit
- Teach pendant
- Teach pendant cable
- Operator panel board
If anyone could give me an advise, will be great, thank you guys.
