Function Generator
  • wes_mcgee
  • March 8, 2019 at 1:16 AM
  • wes_mcgee
    271
    Another old thread comes back around....function generator in KSS 5.x
    I have the manual, which is quite helpful relative to any documentation on the newer KSS versions. But still missing a few pieces.
    Currently trying two approaches, one being to use $DIGIN1 , since I am not using analog. My sensor data is mapped in via devicenet as a 32 bit signal. Also using KukaVarProxy (works quite well for some things actually).
    My current issue with the digin, is that it has a scaling issue. I am baffled by this, but there is a lot of code on this old robot. I am pretty sure my bytes are mapped correct, and currently I am trying a DWORD on my PLC to 32 bit INDW in the IOSYS, with the DIGINCODE set to #UNSIGNED. But the signal has a nonlinear scaling ? PLC=500, DIGIN = 1000; PLC = 1000, DIGIN = 1250. Is the tech function persistent? I even rebooted.
    Alternate method, the #DATALINK class. Writing a correction frame would be ideal, I have multiple ways to accomplish that. But how do I link the FRAME, I assume its not linked the same way as TECHIN normally is linked to the analog or digital? Why they completely omit that from the manual is a bit surprising.
  • fuzzy_l
    61
    • March 27, 2019 at 12:55 PM
    I couldn't use DIGINCODE.
    The information I took from For KUKA System Software 8.1, 8.2 and 8.3:
    Page 102.
    SIGNAL $DIGIN1 $IN[20]TO $IN[27]
    DECL DIGINCODE $DIGIN1CODE=#UNSIGNED
    DIGIN on $TECHIN[2] = Faktor * $DIGIN1 + Offset
    DIGINCODE - I don't have :no1:
    DIGIN - not perceived. :no1:
    What should be added to the robot for DIGINCODE to work? ???
  • panic mode
    1,267
    13,033
    • March 27, 2019 at 3:09 PM
    manual you are referring to is older and this info was still not removed.
    use newer one ("KSS_81_82_83_84_System_Variables_en.pdf")
    and compatibility when migrating from 5.x to 8x ("Kompatibilitaet_8x_en.pdf")
  • panic mode
    1,267
    13,033
    • March 27, 2019 at 3:31 PM
    basically, don't use DIGIN, use ANIN
    you can map bunch of DI to ANIN in WoV
  • fuzzy_l
    61
    • March 28, 2019 at 9:08 AM
    Unfortunately the coordinate of the BOSCH produces in the form of the DINT, and $ANIN[] you can have only INT. The linear distance is 17 meters. There need to precisely DINT :wallbash:
    There are ways to increase the dimension of $ANIN from INT to DINT?
  • panic mode
    1,267
    13,033
    • March 28, 2019 at 1:25 PM
    [size=2]what kind of accuracy do you expect? 16-bit allows 65536 counts.[/size]
    [size=2]17000 mm / 65536 counts is about 0.259 mm per count[/size]
    [font=verdana, arial, helvetica, sans-serif][size=2]what is your application that this is not good enough?[/size][/font]
  • panic mode
    1,267
    13,033
    • March 28, 2019 at 1:52 PM
    one can map sensor data to two analog inputs (low and high word) and then combine them in RSI
    note that analog signals are type REAL, so one gets 6-7 significant figures at best.
  • fuzzy_l
    61
    • March 28, 2019 at 2:02 PM
    Alas I have nothing.
    $TECH[i].CLASS=#CONVEYOR is not supported in new robots
  • RubenRobot
    7
    • April 8, 2019 at 9:51 AM
    Quote from panic mode
    Could you explain how you do this? I have read in the WoV 5.0 manual at the IO mapping chapter, but I havent find anything mentioned of using a bunch of DI to be read as a ANIN by the Kuka system. Or did I misunderstand what you mean here? :flower:
  • panic mode
    1,267
    13,033
    • April 8, 2019 at 1:36 PM
    Everything in KRC is DIGITAL... even ANALOG signals are digitized value, represented by a group of bits. Tou can connect group of any bits (even digital inputs) to an analog input.
