Hello people!
I have a problem with WorkVisual, in my project structure C disk is not appearing when I start working on the project. Look at the attached image!
Does anyone know how to solve it?
Hello people!
it is not needed
but if you would like to add it:
right click on cabinet icon and select "add new folder" and just name it "C". icon will change to drive....
Hello, I added the directory "C" but the files do not appear, I need it to configure the "ConfigMon.ini".
Just add them...
This is OPTIONAL so if you want something in there how do you expect WoV to read your mind? Of course it has to be added MANUALLY
Just add them...
That's what I'm wondering from the start, how to do it manually! You know how to do?
[size=2]seriously? [/size][size=small]isn't this obvious?[/size]
[/size]
[/size]
[/size][size=2]i think that if you put file in WoV in one path and deploy project, file gets transferred to corresponding location at the robot controller:[/size][size=2]if you place file test.src in WoV project \R1\Program\, [/size][size=2]it will get transferred to robot folder [/size][size=small][/size][size=small]\R1\Program\[/size]
[/size][size=2]if you place something random like Pacman.jpg in WoV project under C\KRC\TP\UserTech\Template\, [/size][size=2]this file will be transferred to robot folder C:\KRC\TP\UserTech\Template\[/size][size=small]
Guess what should be done to [/size][size=small]get ConfigMon.ini delivered to [/size][/size][size=small]C:\KRC\User[/size]
