Macrojob, What are?
  • Counterspeller
  • February 22, 2019 at 6:08 PM
  • Counterspeller
    102
    Hello everyone, everything good?
    I wanted to know what macro jobs are, so I use them, as I use them in a touchsense application.
    I also saw the base programs using the CNVRT instruction, why should I use it?
    Thank you!
    Images
      • 36.92 kB
      • 687 × 623
      • 56
    Files
    Touch job.PNG_thumb 21.96 kB – 130 Downloads
  • 95devils
    235
    8
    1,950
    • February 22, 2019 at 7:29 PM
    Any job could be a macro job. It is a form of edit protection. Lower security levels cannot create or modify a macro job. They are typically used with some type of calculations. Instructions the programmer does not want anyone to mess with.
    That macro job looks like a canned job from Yaskawa. Yaskawa has created a macro job that will fit many scenarios. That is a reason the CNVRT is in Base Frame. They (Yaskawa) don't know if the robot is mounted on a base track or is stationary on the floor or riser. Using BF fits those two scenarios. If your robot is not on a base track those instructions could be changed to robot frame (RF).
  • Counterspeller
    102
    • February 22, 2019 at 7:44 PM
    Thanks man!
    I was reading, for the works of touchsense, already have some macro jobs, how can I get them? And in the touchsense programming part, do you know where to start?
  • Counterspeller
    102
    • February 25, 2019 at 11:50 AM
    Quote from 95devils
    95devils?
  • 95devils
    235
    8
    1,950
    • February 25, 2019 at 3:42 PM
    Quote from Roger Alexander Moresco
    Thanks man!
    Call your local Yaskawa office.
    You could download the manual from Motoman.com
  • tonygast
    244
    • February 28, 2019 at 1:45 PM
    The way I think about a MACRO job is, It is a job used as an instruction. One that I have used frequently is a job called Handshake. In a cell that has multiple robots, I set the arguments for which robots are working in close proximity while allowing the others to continue.
    I also use one called CLAMPS to fire outputs for clamps, the argument sets which clamps should be opened or closed....
    Oh, well
  • jjmontero
    • March 1, 2019 at 9:28 AM
    Quote from tony gast
    What is the difference with just calling a normal job with arguments? Other than offering the extra code protection noted by 95devils.
  • tonygast
    244
    • March 1, 2019 at 3:49 PM
    No call instruction...You can disguise them... and can be found in the inform list. That's about it
    Oh, well
    Edited once, last by tony gast (March 1, 2019 at 3:56 PM).
