Hi I am trying to run this s430if with rj 3 controller which was sitting for a while. Getting OVC alarm and weird noise from servo as it is trying to hold position but can't. Took the servo out and runs fine. Put it back in same problem. Can anyone help please. Thanks
Ovc alarm
Arvi -
February 22, 2019 at 5:50 AM -
Check all connections. And check the incoming power.
Hello Avri,
it sounds like that the brake will not open. Do you hear thle "clack" ?
If it is not the brake, there is a mechanical problem.Matthias
Hi Guys
thanks for the replies. I have checked the incoming power which is ok. I thought it was the brake but when i removed the motor from the frame and ran it on the desk with everything plugged in, it runs fine. brake works the way its supposed to. Looks like the servo is finding difficulties in holding the position while energized when in place . Which could be something mechanical according to Matthias. This problem is with axis 3. I am not sure how to diagnose the mechanical side of this issue.
