SafetyConfiguration.sconf
  • Hi,
    I would like to be able to add joint position, velocity and torque safety limits to the IIWA. For a bit of context: I am running the robot in AUT mode
    whilst sending torques via the FRI. I would like to have safety values set up in order to not blow a fuse when I do something bad, but rather have the robot
    just stop.
    When I go into the safety configuration option on Sunrise I am unable to add more than 3 axes to the workspace limit. This is because
    I only have only three instances for some reason which act as group. I have attached a few pictures of what I did to add axis limits.
    Also I seem to have have the option to add joint velocities.
    Any help is welcome
  • For this purpose it is sufficient to use the collision detection AMF. If the robot is to be used in a production enviroment the you need to do risk assessment and probably use more safety functions.
