Registers values change
  • Hello everyone!! :help:
    At one of my applications, i have used robot with controller R30iB.
    My problem is that without any reason, the values of some registers can change randomly, while the robot is working.
    i check the program and i am sure that there are no commands which set the values of the registers.
    I also stopped the communication with the PLC.
    Have you ever faced such a problem??
    Do you have any idea??
    thank you in advance!!
  • The following could be changing R values, in order of probability:
      • Foreground program in TP.
      • Background program in TP.
      • Macro TP program being fired by something (DI/DO/UI/UO, etc).
      • Separate Foreground program in TP running in parallel.
      • Background (or shell) program in Karel (if equipped).
      • Operator screwing around with the pendant.
      • Robot's internal PMC (if equipped). Kinda iffy on this on. Need to check if the PMC can actually do this.
      • Explicit messaging via Ethernet I/P (if equipped).
      • Modification from remote device via ethernet SNPX protocol (if equipped, Basic HMI option).
      • Someone modifying a value via the robot's comment webpage.
      • Someone modifying a value via the a custom built webpage present on the robot.
      • Someone using Fanuc's propriety protocol that robot server uses.
      • Loading of numreg.vr.
    I'm sure there are a few more methods, but these are the ones I can think of off the top of my head.
  • the strange is that does not change always a specific registers. sometimes changes the value of register 30 for example and sometimes the 62 or 75. Not always the same. And i dont use at none of my programs indirect addressing to registers!!! :waffen100:
