Hi there,
I'm working with KUKA KRC4 robots and for my application it would be of interest calculating the mass of the object that my robot is handling.
The variable $TORQUE_AXIS_ACT is according to the system variable the actual torque of the motor for the specific axis, does this allow me to calculate the mass together with my acceleration variable, and can I do it "on the fly"...? Lets say I choose to do a LIN movement, and with my torque and acceleration variable I can define my weight, buy using (M=r*m*a), where r is the distance from the mass center. (the mass center will vary slightly when the object mass changes, but there are ways to come around this, and M is my net torque that I can derive from the actual torque variable)
I'm wondering if anyone has tried to one way or the other way calculate the payload by using these variables? And what would the tolerances be? Are we talking (+-)Kg or much less, more?
Lets say the above mentioned method is faulty, would using a force/torque Sensor be a smart method of get proper values that I can use to calculate my payload with much better tolerances, or is it a totally wrong approach to use such a sensor?
The weight I want to calculate is primarily around 20-40kg, but there is also an interest to do the same calculations with bigger robots that is handling objects up to 250kg.
Thanks for your time
