KRC2 fast measurements X11 connector in the RDC box diagram/pinout
  • vvelikov
  • January 19, 2019 at 11:10 PM
    vvelikov
    486
    Hello everyone :smiling_face: and all the best for the New 2019 Year!
    I am trying to use the fast measurement inputs on a KRC2 robot so i can do a proper TCP calibration device.
    I asked KUKA for the X33 KRC2 kit but unfortunately they are not selling that anymore.
    So i am thinking to make the wiring myself but i cannot find the X11 (on the RDC board) pinout anywhere :loudly_crying_face:
    Can somebody help?
    Thanks!
  • panic mode
    1,296
    13,136
    • January 20, 2019 at 3:50 AM
    really? what article number? KRC2 is retired but less than 10 years ago so all parts should be readily available.
    vvelikov
    486
    • January 20, 2019 at 10:37 AM
    I don't know the article number - i struggled to find any info about Fast measurements kit etc.
    The answer was that the "for KRC2 the fast measurement was discontinued, we are not able to offer it any more"
    So any info about this will be appreciated - i have X11 on my RDC - so i suppose it shouldn't be a problem to connect a sensor to it.
  • SkyeFire
    1,060
    9,456
    • January 21, 2019 at 5:04 PM
    Hm... well, on the KRC2, the Fast Measurement inputs should be a small unoccupied 7-pin linear socket (Lumberg connector?) on the RDC card, on the opposite side from the 8 Resolver inputs.
    I'm not finding a pinout of that connector right now, but it's pretty simple -- there's a 24VDC source, a 0VDC common, and 5 fast-measurement inputs. The inputs are designed for taking simple "dry contact" style signals, IIRC, like a prox sensor or optical switch. The sensor draws its power (if it needs any) from the 24VDC and 0VDC lines, and closes a contact between the +24V line and the sensor input to provide the "contact" signal. Basically, the Fast Measurement input should be tied to the 0V line until the sensor trips, at which point it should be tied to the +24V line. A relay would do it, but would probably be a bit slow.
    Alternatively, you can source an external supply's 24VDC to the inputs, as long as the 0V line on the FM socket is tied to that supply's 0V line, and the FM socket's +24V is left unconnected.
    You could probably build your own breakout cable and reverse-engineer the pinout, by being very careful. The nice thing about FM on the KRC2 is that, aside from the X33 breakout, you don't need anything special.
  • panic mode
    1,296
    13,136
    • January 21, 2019 at 5:39 PM
    this should be it but be careful and check voltages first.
    Images
      • 69.05 kB
      • 705 × 410
      • 99
    Files
    KRC2 X33.jpg_thumb 16.94 kB – 171 Downloads
    vvelikov
    486
    • January 21, 2019 at 6:30 PM
    Thank you so much! That was all i needed - will try it out and report back once it is done :winking_face:
  • panic mode
    1,296
    13,136
    • January 21, 2019 at 6:31 PM
    i guess i will have to setup Fund My Beer account :smiling_face:
  • SkyeFire
    1,060
    9,456
    • January 22, 2019 at 9:02 PM
    Quote from panic mode
    :party21::beerchug::uglyhammer2:
    vvelikov
    486
    • January 26, 2019 at 9:39 AM
    Absolutely!
Users Viewing This Thread
  • 1 Guest
