Hello all,
This forum is very useful so thank you to all moderators and contributors, may it continue! Now I don't tend to be in such a pickle that I need to post my own problem on a forum but right now I am! This is my first post on the forum so lets hope i've read the "READ BEFORE" thread...My problem:
- I am using WorkVisual 5.0.7 (I was using 4.x.x before updating to see if the problem fixed itself) and OfficeLite 5.0.7.
- My virtual controller version is KRC 8.3.4.
- My task is to create a copy of my real controller on the virtual one, using "deploy" on workvisual. I have ensured DTM catalogs are available to workvisual although I don't any KOP files.
- I have tried different configurations before deploying. An exact copy of the "real" controller, a merge between the real and virtual controllers and then I have tried to set up the virtual controller configuration manually in workvisual. None have given me a usable virtual controller.
- My main problem and worry is that when I am on the "programming and diagnosis" section of workvisual I cannot open up the file system due to an error from workvisual that the "controller is not supported - it must be 8.3.14 or later than 8.5"
I have attached the actual error message and the virtual controller info tab.
So if anyone can offer some advice on whether I lack configuration files/set-up in workvisual, whether i have to update officelite controller/KSS version or if I need new version of officelite altogether then I'd be very grateful. I only started working with robots 4 months ago and yet inherited a robot at a university that had not been commissioned and set-up right in 2 years... I've managed to set-up everything up, now I only need to complete the offline programming environment before an accurate position calibration and I'm done!
