Hi All,
Controller KRC4, V8.3 B450
I have a quite specific problem (couldn't find topic with this issue on the forum) regarding touch probe connected to the X33 interface and interrupts. So, what I want to achieve is a calibration feature by moving the robot manually in T1 instead of programming any motion before. The system has to be flexible.
Basically, the sequence of steps would be like:
-Define and start interrupt,
-Move the robot manually in T1 to the point until interrupt is triggered by touch probe,
-Save joint pos. to the variable,
-Continue manual movement to another point and repeat sequence.
My problem is, that if I create my own program, after touching the point with a touch probe, to go inside of the interrupt I have to click play button on the smart pad and I would like to avoid it. Without that, my interrupt function will be never executed. Does anyone ever tried to implement something like this or know how achieve it?
