Good morning,
2x KR10R1100six | PLC S7 1500 | WOV 4.0 | KSS 8.3.33
I want to establish a safe communication between two KUKA robots KR10R1100sixx recently installed. Each robot is already equipped with :
• 1x EK1100 | EtherCAT Coupler.
• 1x EL2809 | HD EtherCAT Terminal, 16-channel digital output 24 V DC, 0.5 A.
• 1x EL1809 | HD EtherCAT Terminal, 16-channel digital input 24 V DC.
My idea is to add :
1x PLC. Beckhoff
2x safe digital input module ( one for each robot ).
2x safe digital output module ( one for each robot ).
The EtherCAT output of the PLC ( Beckhoff ) will be connected to the EtherCAT input of the coupler ( first robot ), and the EtherCAT output of the coupler ( first robot ) will be connected to the EtherCAT input of the coupler ( second robot robot ).
The safe outputs ( robot 1 ) will be wired to the safe inputs of ( robot 2 ).
The safe outputs ( robot 2 ) will be wired to the safe inputs of ( robot 1 ).
I want to know your opinion about this solution for that application or propose me a better idea if there is.
Thank you.
