MFRAME
  • d.chlebek
  • January 16, 2019 at 7:58 PM
  • d.chlebek
    7
    Could someone explain me basics of configuration MFRAME functions?
    I coudn't find any solution in manuals...
    I need some rule to offset my user frame.
    Best regards
  • Robodoc
    56
    7
    1,061
    • January 19, 2019 at 2:13 PM
    The MFRAM instruction takes three position variables and makes a user frame out of them. The command MFRAM #(x) P000,P001,P002
    x is the user frame number you are making
    P000 is the ORG position
    P001 is the XX position
    P002 is the XY position
    (P000,P001,P002 are just examples, any P variable address can be used)
    Robodoc
  • d.chlebek
    7
    • January 21, 2019 at 3:48 PM
    Ok, I get it.
    I need to create the user frame in the box. If I move the box for example x=100 mm, all of my moves should offset 100mm too on the x coordinate.
    Could somebody explain me this?
  • Robodoc
    56
    7
    1,061
    • January 26, 2019 at 1:56 PM
    If you want to move your positions relative to something you need the purchased option of relative job.
    With relative job, you make your job relative to something (user frame, tool frame..). If you now change the data that makes that frame the robot will move with it.
    Robodoc
