Quick question.... Is there a way to set the job speed to 50% or less with the pendent? I don't have access to the plc. Its easier to see what is going on with the EOAT inside the press at a slower speed. Running DX200 with MH24 for press tending. Thanks
Setting the job speed
- Booradley20
Set S2C701 = 1, S2C709 = 1. I know you are handling, but if you have any arc welding also remember to set S2C1135 =1. This enables Speed Override (this info is also for others who may read this thread!)
When you switch to auto you will then have possibility to change speed while to robot works. If welding, set S2C1135 = 1, then when the ARCON command is processed the speed override is disabled until ARCOF.
Hope this helps!
By changing these parameters i wouldn't be messing with the plc just the controller, correct?
No, if modify is off, then you are just having the controller run the jobs at a percentage of program speed. The controller will not overwrite the speeds.
