MOTHER BOARD - FTS D3076-K - KRC4 - FAIL LED ON
  • Visentainer_Sulivan
  • January 3, 2019 at 12:26 PM
    93
    Hi all,
    Today I received a KPC from KRC4 STANDARD (KSS default 8.2), and it is not able to load the inteface.
    I tried to connect an external monitor DVI but it shows nothing.
    After this I tried to change some devices as RAM memory and dual nic, without sucess.
    But I saw a strange red LED on mother board behind the KPC power supply. It was a fail LED indicator as we can see in the pictures.
    I tried to find this mother board datasheet, but the PDFs that I find wasn't so detailed to show whats kind of problem the board is.
    Does some one knows what kind of problem the red LED indicates?
    Does some one have already acessed an full KRC4 mother board data sheet?
    Maybe can I fix the board exchanging some components? Or will be necessary exchange the board?
    Images
      • 536.54 kB
      • 464 × 623
      • 59
      • 625.82 kB
      • 469 × 625
      • 39
      • 676.61 kB
      • 468 × 618
      • 37
      • 762.35 kB
      • 467 × 623
      • 37
    Files
    mb1.PNG_thumb 30.28 kB – 275 Downloads mb2.PNG_thumb 35.08 kB – 260 Downloads mb3.PNG_thumb 36.48 kB – 249 Downloads mb4.PNG_thumb 38.79 kB – 250 Downloads
    Sulivan - Automatikbr.com
    Robotics Technician Brazil.
  • panic mode
    1,262
    13,027
    • January 3, 2019 at 1:09 PM
    It means that motherboard is defective (selftest failed).
  • FernandoAR
    13
    • November 1, 2020 at 2:35 AM
    Hello!!!
    Did you change the motherboard or it was a powersupply fault?
  • Mojtaba Rezaei
    • February 12, 2022 at 5:18 PM
    the defect of the tin is dead, revive it, it will be fixed
  • Mojtaba Rezaei
    • February 12, 2022 at 5:20 PM
    Dead tin causes a voltage drop and gives the voltmon fail
  • fusioon
    5
    • December 12, 2023 at 2:13 PM
    Hello Mr. Rezaei,
    could you describe more precisely what it means "tin is dead" and where I can find and restore it...I have a problem with a dead motherboard / KPC - KRC4 /
  • panic mode
    1,262
    13,027
    • December 12, 2023 at 5:55 PM
    i think he meant to say that issue could be caused by poor solder joint and reflow may fix it.
  • sarathlalm83
    • October 22, 2024 at 10:50 AM
    May i know this motherboard is compatible for updating KSS 8.5? How i can find this.Could you please help me out
  • vvelikov
    484
    • January 9, 2025 at 4:41 PM
    Quote from Visentainer_Sulivan
    Hi all,
    Hello, what was the solution in your case? Did you managed to fix this? I have the same problem with a KRC4 compact cabinet - the robot was working fine untill a small piece of plastic went into the fan and stopped it. Afterwards we have a red led and no signal on the motherboard.
  • vvelikov
    484
    • January 9, 2025 at 4:42 PM
    Quote from Mojtaba Rezaei
    Where we need to revive the tin? Which part of the motherboard?
  • ArcGroup
    • January 10, 2025 at 4:37 PM
    • #11
    Try changing the CMOS battery first. The BIOS may need to be updated as well.
    I believe it is a CR2032, it has been a while since I have replaced it.
    93
    • January 10, 2025 at 5:40 PM
    • #12
    Quote from vvelikov
    Hi vvelikov That time we bought a new Mother Board.
    Few months ago we had the same problem 2 times.
    1 - Solved with a new CR2032 Battery.
    2 - Not Solved yet, we believe it can be processor socket pin damaged.
  • vvelikov
    484
    • January 10, 2025 at 5:53 PM
    • #13
    Thanks! WIll give it a try and write back the result
